Installing interior neons
Old Aug 17, 2005
chriscivic04's Avatar
chriscivic04 is an unknown quantity at this point
I recently installed a complete interior neon kit on my 04 civic lx, the only trouble I'm having is getting the wire through the firewall to the battery, if anyone can help it would be greatly appreciated.
Old Aug 17, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Hey new Jack. U should use that little search button on the top of the page. It will bring up previous threads about the same thing. Just type in neon install or something to that effect.
Welcome to the site
Old Aug 17, 2005
Kyle23's Avatar
I just typed in neon installation and u should use the thread by GearBox that is labled ask me about DIY stuff. He or somone else will get back to 2 about it very soon. Normally I would provide the link but u need to learn how to search... so u can do it
Old Aug 17, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
go to the tool bar just above the google ads at the top of the page and click on the DIY button then go to audio and select Amp Wiring: 2k1 Civic Coupe dont worry your car is the same.
Old Aug 17, 2005
I sort of glimpsed through a few of those, but I'll go check that one out specifically, thanks.
much appreciated
Old Aug 17, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Just in case let me help. There is a rubber grommet behind the passanger side carpet towards the center console. Take a wire hanger and straighten it out. Doesn't have to be perfect but straight enough so that it won't get caught on anything. push it through the grommet far enough so that you can grab it from the engine bay, but not to the point that you don't have any in the cab. get the line that you want to run to the battery and place it on top of the hanger. Now tape the hell out of it. I recommend electrical tape cuz well... I'm mexican and that is a staple..... Once it's taped to the hanger, go to the front, grab on to the hanger and pull slowly. you may have to give it a hard tug once you get to the tape, but don't pull too hard or it's going to fall off... That's it... If you have any problems feel free to PM me...
Old Aug 17, 2005
So I don't need to remove any panals or anything? Just wondering because the thread the other gentelman referred me to mentioned removing 3 panals.
The help is much appreciated,
Chris
Old Aug 17, 2005
Nope... That's for running a power wire to an amp in the trunk. What he wanted you to see was where to break through the firewall.
Old Aug 17, 2005
nick95673's Avatar
dude you can take from a book named the how to build a house book and learn how to make base boards come together without being forced to build a whole new house. why cant you take the part about getting the power wire through the fire wall and use those directions and disregard all the rest. i mean i would describe myself as average to less than average on common sense but c'mon guys you should pay someone else to do the work if you cant figure out how to apply knowledge.
Old Aug 17, 2005
As to most of what you just said, I honestly didn't have much time to do research myself or you're right I could have figured it out through an already exhisting post. However I just had a quick, simple question, that I didn't have time to go through other articles for so I asked and got my response here. Much appreciated stpyro8.
Old Aug 17, 2005
nick95673's Avatar
it took more time to type this than it does to click on diy then audio then read the post if that wasnt enough then you could ctrl+f and enter fire wall and still took less than 2 minutes.
Old Aug 17, 2005
Kyle23's Avatar
Nick - I luv ur smart azz remarks, they always make me laugh.
Chirs- Good job at not blowing up at Nick.
Let's not start a war . ok that's enough of my pointless post
Old Aug 17, 2005
EnProceso's Avatar
like someone said earlier there is a gromment under the dash on the passenger side. or do what i did and tap into the cig. lighter wire, but they will only work when the key is on acc. or when the ignition is on.
Old Aug 17, 2005
jay78's Avatar
jay78 is on a distinguished road
i drill a hole under the staring....easy...
Old Aug 17, 2005
Sort of as a follow up question on this, I got everything through the firewall, all that good stuff, afterwards i took the positive wire and hooked that up to the positive port on the battery, and the negative one just on some random skrew. For some reason it still isn't working, any ideas?
Old Aug 17, 2005
nick95673's Avatar
is there try disc the ground from the battery and put it on a clean part of the engine bloch and see if that works if that doesnt it could be alot of things like a bad switch bad bulb....
Old Aug 17, 2005
CraigW's Avatar
Make sure you use a fuse at that battery connection !!
Check and re-do the ground connection or use a wire and jump the ground to a known good ground for a quick and easy test.
Old Aug 17, 2005
jay78's Avatar
where did u ground it now ???
connect to battery try...if dont work then i would chek all the wires...make sure u connect them correct....
Old Aug 17, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
Make sure u have a remote wire running to the amp. May seem stupid but it has happened to alot of us without thinking about it.
Old Aug 18, 2005
EnProceso's Avatar
LOL hes hooking up neons not an amp
try a different grounding point.
recheck your connections and crimps, make sure they are tight and solid.
if all is good, check your neons, what brand you using?
this might sound stupid but make sure your connections to the switch is correct, even i had to make a thread to help figure out which prong connected to which wire.
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
