HU wiring, which orange wire to use?
Old Jan 31, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Here's a technical question for you. On my new HU, an Eclipse 54410, it has an illumination wire lead, and its orange. On the stock wiring harness, there are 2 illumination wires, an orange illumination, and an orange/white illumination dimmer.
I plan on using the the stock orange illumination wire, but would the orange/white make any difference, or is it to ONLY adjust the brightness? (IE, wouldn't make my new HU light up when powered)
Or, could I use the stock orange/white, and get an adjustable illumination?
Just wanted to see if any of you guys knew, if not, when I install my new HU, I'll just play with it and see.
Old Jan 31, 2002
VNlilMAN's Avatar
The Standard One
you know what, i tried both n they both do the same thing for me.... my kenwoods headunit's button is always on... i'm thinking its always on cause of the headunit n not cause of my mistake
Old Jan 31, 2002
Slammed2k1's Avatar
Slammed2k1 is an unknown quantity at this point
On the 54410 it is just a dimmer, when you turn your lights on it will dim your display. The older Eclipse hu's light up when you turned on your lights. SO hook that wire up to your illumination wire, orange. The orange/white wire varies voltage when your dimmer is turned, and won't do anything for you but possibly damage your dimmer circuit in your car.
Chris
Old Jan 31, 2002
mohawkboom's Avatar
What Slammed said..
Also.. I have the Eclipse 8051.. but I bought it slightly used and never had a Manual for it.. I believe your Model and mine Are identical except for the pre-outs.. any chance you can photo copy your manual and mail it to me?
Cheers
Mohawk
Old Feb 2, 2002
0100010's Avatar
Sure, email with your address and I can get it to you in a few days. Thanks on the info Slam.
SimpleUser
Apr 24, 2021 02:54 AM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
