Is this a good setup?
Old Aug 11, 2005
Pagz69's Avatar
Pagz69 is an unknown quantity at this point
Question Is this a good setup?
Well I just bought my system i know nothing about audio so i just trusted the sales guy is this a good setup? I originally had two 4 channel alpine amps each hooked up to each sub, but I exchanged them for this amp for more power to each sub. any suggestions on changes? cause i still have time to exchange.
Alpine MRD-M605 Amp
Alpine 10" SWS-1022D Subwoofer x 2 in a sealed box
I already have a pioneer head unit.
Old Aug 11, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
yea that's pretty sweet. its a mono amp and does 600rms x1... it shoud sound good.
Old Aug 11, 2005
Pagz69's Avatar
Do i need a ported box?
Old Aug 11, 2005
2k5EP's Avatar
2k5EP is an unknown quantity at this point
Yeah i was gonna do that setup but i could only get the 4ohm version so i had to use a kicker 550.2 amp
Old Aug 11, 2005
2k5EP's Avatar
i have mine ported and they sound sweet i haven't installed the kicker amp yet they're running off a 300 watt Virtual Sound Amp... I had them in a sealed box that i bought from circuit city and they sounded shitty so i made a box exactly like the vented MTX one they sell there and they sound amazing... Also take off the rubber around the magnet... They sound better with it off and it supposed lets it cool better... Umm other than that be careful about turning them up really loud or you'll blow them... They are known to have weak voice coils (why i got a ported box)
Old Aug 11, 2005
MegaHurtz's Avatar
it's an okay setup, not great, but youll probably like it.
Old Aug 11, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
That's the amp I have in my car and I like it.
Old Aug 11, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
What is the advantage of having 2 subs in a compact!? Still not understand...
Old Aug 11, 2005
82801BA's Avatar
Hey, how can you get 14.32 reading on the cap? I am always getting 13.6-13.9, what's wrong with mine?
Old Aug 12, 2005
05reverb's Avatar
regular altenator voltage is 14.4volt (approximatly), so when there is nothing running in your car it should be close to that, when you got your sub on or other stuff draining power, it might change the voltage going to your cap.
Old Aug 13, 2005
cravinspeed's Avatar
cravinspeed is an unknown quantity at this point
its a good thing you got the 2 ohm voice coils otherwise that amp would be incredibly unstable. the sound wont be as clean with a 1 ohm impedance for the amp but it will def be louder. overall good setup. and no need to port the box unless you have an underpowered amp for the subs which you dont
Old Aug 13, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
More air being displaced = more volume.
I have 4 subs...
Old Aug 14, 2005
true dat... but a system that sounds clean is all you need IMO
Old Aug 14, 2005
Mystic3030's Avatar
Well everyone has a system for different reasons. Some people just want to rock the block, some people want SQ. Some want both. When I went for 4 subs I was competing with the car for db drag.
Old Aug 14, 2005
whats your sys? right now i'm rockin boston interiors, mtx 12" 400w, and alpine v12 amps...all i need to be happy
Old Aug 15, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
His will probably drop down to the same level as yours. He probably took that picture a couple of weeks before he installed that cap, and charged it.
My cap used show voltage between 14.1 and 14.4 constantly. How do I know you ask?? I started my car, turned on the system, and watched the voltage on the cap. Its been about 3 or 4 months since I got my capacitor. Mine reads constantly from 13.6-13.9 as well. So I believe its normal.
My cap only shows voltage at 13.6 or sometimes a little lower when the bass hits hard. Other than that, its usually around 13.7-13.8 constant.
Old Aug 15, 2005
nothing is wrong with them... its normal, but if it were to get down to 12 i would start to get worried. idealy you want your system to run at 14.4 to get the best performance. 13s you wont really notice a difference though. and mine runs at only 13.6 constantly. general rule for caps is, 1 farad per 400-800watts total system power
Old Aug 15, 2005
Mystic3030's Avatar
Four JL Audio 12W3v2 in 1.25 cubes each, sealed
Two JL Audio 500/1
MB Quart QSD216
PPI PCX 4125
Alpine 9835
XM
iPod
H/O Alt
DuraLast Deep Cycle
Old Aug 15, 2005
nice f#@$in setup!
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
