Aftermarket radio problem&#?%
Hey, just installed a Blaupunkt V-Line unit in my 05.
I followed wires DIY and plugged antenna (blue) with yellow/green stripped wire. Put everything back in place.
1. Unit not working
2. Door lock not working
I checked my fuses and bad grounds..
What the hell is going on?? Oh yeah and what's the illumination wire for..? My radio aint go nothing for that. As i know this as all probably been covered in previous posts, i searched, but without success.
Thanks for your diy Megahurtz
1. Unit not working
I spend way too much time on this website
with plug in harness
blue/white -- power antenna turn on
red -- 12 volts switched power
violet -- Right Rear speaker pos.... violet/black -- neg
Green -- left rear speaker pos..... green/black -- neg
gray -- right front speaker pos... gray/ black -- neg
white -- left front speaker pos.... white/black -- neg
orange -- illumination (not used in our car... tape off)
yellow -- 12 volts constant
orange/white -- dimmer
black -- ground
black -- ground
lol. well that is not correct always. Each harness may have different wire codes. For example, my power antenna wire was blue, not blue/white. What you need to do is look at the codes on the back of the wire harness and then look at the ones on the instruction manual for your deck. Match them to what their functions are, not wire colors. Check all your fuses, because you blew saomething. The illum(ination) wire is only on some decks. It makes the deck lights dim when you turn on the car dash lights.
h4ldol
Apr 24, 2017 08:16 PM
ricer_em2
May 11, 2016 08:09 PM
Mc7602
Sep 17, 2015 02:01 PM
