Help Pls........
Old Aug 6, 2005
flipcrip's Avatar
flipcrip is an unknown quantity at this point
Unhappy Help Pls........
Sup? Just Wonderin If Anyone Can Give Me A Couple Of Suggestions. My Dash Lights And Rear Lights Just Went Out Last Night. Can Anyone Please Tell Me Which Fuse Or Fuses Run These Lights. Note: Just Before This Happened, I Heard A Crackling Sound From Inside The Some Where Around The Radio......all Your Suggestions Would Be Greatly Appreciated
Thanks
Old Aug 6, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
wow there has been a rawsh of these lately. theres a fuse box under your steering wheel and one under the hood on the pass. wheel well. the fuse guide will be on the inside of the lid of the fuse box. also just because a fuse doesnt look blown doesnt mean its still good.
http://www.7thgencivic.com/forums/sh...nd+tail+lights
dont feel bad to use search
Old Aug 7, 2005
CraigW's Avatar
Fuse 2 and fuse 5 in the under hood box.
The cracking noise does not sound good.
Any recent head unit installs by chance ??
Old Aug 7, 2005
skipbarber's Avatar
illumination wire probably grounded out, and most likely still is. Id remove the radio and wiring before replacing that fuse, otherwise you could turn something as simple as a fuse into something worse.
Old Aug 7, 2005
zen_master's Avatar
omg....again??
the cracklingn noise probablyt comes from the relays of cabin fuse box..
but AGAIN...like im my case.it might not because of the relay...but the whole multiplexor (the fuse box)...
Old Aug 8, 2005
flipcrip's Avatar
Sup Guys......
I Found The Fuse That Was Blown, And I Replaced It. It Work Fine For About Half An Hour And As Soon As I Turned The Radio On The Dash And Rear Tail Lights Go Out....so I Tried Replacing The Fuse Again And I Notice That When I Turn The Radio Is On And As Soon As I Switch Turn The Dash Lights On The Radio Goes Out For A Few Seconds And Then Turns Back On Again.....unfortunatly I Cant Say The Same With The Dash Lights And Taillights........is There A Loose Wire In The Stock Radio???....thanks
Old Aug 8, 2005
zen_master's Avatar
geez...........
it might be............just like my case......
what year is ur honda?
let the dealer check it...........ask them is it the multiplexor (under steering fuse box)?
Old Aug 8, 2005
flipcrip's Avatar
My Ride Is An 04
Old Aug 8, 2005
CraigW's Avatar
I would re-check all connections to the head unit and associated wiring. Check the illumination leads in particular
Old Aug 8, 2005
flipcrip's Avatar
Thanks For The Suggestions Guys.......i Kinda Solved The Problem.....the Only Thing Now Is That I Have No Radio......i Removed The Fuse For The Radio, Before I Placed A New Fuse {#2} Under The Hood.....the Dash Lights And Rear Tail Lights Are Now Working Normally, But As Soon As I Put The Fuse In For The Radio, Everything Gets Messed Up Again......does This Suggest That There Is Something Wrong With The Head Unit? Also,"craig W" How Do I Check The Illumination Leads? Are Thosse The Leads Behind The Factory Head Unit?.....thanks For The Info Everyone
Old Aug 9, 2005
zen_master's Avatar
Dude....................
u put it #2, everyhing messed up again?
Jesus christ Lord........how many people already with the same problem?
listen to me, it's exactly the same like mine.........it's just that....it hasn't gone that far like my car.......
in my case, it's #2 and #5.
if i plug em in, dash light all lit up....Error......and i can't start my car..
got the checked...........for fvcking stupid $200 in honda, they 99% belive, multiplexor is the problem. it's weak, that's what they said.
NOW...if ur problem gets worse......like mine..........when u turn off ur car....the headlight will light on......in my case, i've to take out my battery cable everytime i park my car......
THIS is just basically the same problem.........but a different variant.....all and all...the multiplexor is the problem. IMHO.
this is what it looks like..
this is the diagram of the fuse box..
did i explained it good enough?
Old Aug 9, 2005
CraigW's Avatar
www.installdr.com and www.metraonline.com
The illumination lead is tied into the dash lights circuit, which is tied into the tail lights circuit. It allows the head units illumination to function when the lights are on.
Most units use orange or orange/white wires.
Old Aug 9, 2005
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
sorry if i sound like an a$$, but i found it funny that you spaced everything with series of periods. funny i could so picture you talking really slow like trying to explain something for the 6th time.
Old Aug 9, 2005
zen_master's Avatar
^lol...
indeed............
i explained this....i don't know how many times to many members.......
thing is.......if u lost $200 for diagnose, $120 for the part....and yet $80 for replacing it....with no guarantee that it won't happen again for the second time..........................
once again......NO guarantee that if today it's fixed......the next day...or the week after.......same thing happen again *KNOCK on Wood*
think about it: even till now, i have NO idea what causing it!
My 04 tail conversion? My headunit? My amp? My sub? what? why? when? how?
This is pissin' me off!
so...................then, ur' gonna start *sigh*-ing....
u know?
note: i know somebody gonna say, "calm down, man........"
Old Aug 9, 2005
mkymonkey's Avatar
calm down man.....
jk i just said it cuz you said so
Old Aug 9, 2005
zen_master's Avatar
^hahaha, thanx man...u cheered me up for today, lol....
OP, sorry for "hijacking" ur thread.....just to let u know my situation....which might be or something similar to ur case...
hopefuly ur car will be ok too...
Old Aug 9, 2005
flipcrip's Avatar
"zen master" thanks for the info. i just have a couple of questons to ask you. before dishing out the cash for that multiplexor, i really want to try to solve this problem on my own "if possible"..lol. last night i realized that when only the radio is on that when i tapped the area around the top of the dash, a crakling sounds comes from the front driverside speaker. but as soon as i turn the radio off, and tap again there is no crakling sound from the speaker. which in turn makes me believe that there is something loose behind the dash or head unit. did this happen to you? also, do u know what wires are linked to the front speakers and what fuse......thanks for your help man
Old Aug 9, 2005
zen_master's Avatar
ah........
hold ur horses on the multiplexor, dude..
bad news on my car......they changed it, but it didn't really fix em all..
ah...........as far the relationshi with radio, i really can't help you with that, bro.....my problem doesn't really related to radio.....but the lights.......dash lights, headlights, small lights and all that.
its' bad.
