Subs Out, what about wires?
Old Aug 5, 2005
manahoonie's Avatar
I GOT A QUESTION!!!!!
I am re-doing my trunk setup for my subs. Here is what i have done (in order)
1. I disconnected the positive power for the subs (without disconnecting the positive for the rest of the car).
2. i then went and disconnected the negative battery, so i could work in the trunk.
3. i disconnected the grounds for the amps
4. disconnected the positive
5. disconnected the remote wire (in this case a little blue wire that tells the amps when to turn on and off)
NOW. I figure that the grounds and positive cables are alright, as the positive cable is now just a cable running from the engine bay on back to the trunk, and the grounds are just kinda sitting there.
WHAT ABOUT THE REMOTE WIRES?
AM I OK TO RECONNECT THE NEGATIVE TERMINAL ON THE BATTERY? (sub box is staying out for a little. too heavy to take in and out all the time)
LET ME KNOW!
Old Aug 5, 2005
EnProceso's Avatar
are you talking about the speaker wire?
Old Aug 5, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
all you need for safety is to discon the pos at the bat or pull the fuse from under the hood. and as long as the stereo isnt turned on dont worry about the remote
Old Aug 5, 2005
manahoonie's Avatar
so, if the remote is still connected , i cannot listen to the radio?
Old Aug 5, 2005
manahoonie's Avatar
the remote wires. the ones that tell the amps when to turn on and off
Old Aug 5, 2005
MegaHurtz's Avatar
if the amp is staying in just leave the remote wire alone
Old Aug 5, 2005
EnProceso's Avatar
i thought you said you already disconnected that. but yeah just leave it in. if your + and - are disconncted from the amp it doesnt matter cuz then theamp is basically a paper weight right now cuz no power is getting to it. your fine to reconnect the negative terminal.
Old Aug 5, 2005
manahoonie's Avatar
ok. i got my answer. i cover up the remote wires, then i'm ok to turn the radio on and off. i i leave them exposed, and they touch metal, i'm screwed.
i have been talking about the remote wires, the little wire(s) that tell the amps when to be on or not.
Old Aug 5, 2005
EnProceso's Avatar
just leave the remote wire in the amp, its not gonna hurt anything, it would tell the amp to turn on when you turn on your HU but since the amp is disconnected its not gonna do anything.
Old Aug 6, 2005
manahoonie's Avatar
i'm sorry i did not say this in the original statement.
The Amp Is Not In The Car! Therefore, I have a remote wire going to the trunk with nothing to connect to. i got my answer of just wrap it up, and it should be fine!
Old Aug 6, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Make sure you also cover up the main power wire running from the engine bay
Old Aug 6, 2005
2k2civic's Avatar
I would say just tape it up and make sure it won't make contact with anything and you should be fine. If your wanna be really sure though, just crimp on a butt connector leaving the other side open, then tape over that (the plastic insulation of the connector will be a little added peice of mind).
Old Aug 6, 2005
jttegx's Avatar
OMNES AD UNUM
electrical tape the ends, remove fuse from power wire, no worries...unless you have a cap that still has juice in it still
SimpleUser
Apr 24, 2021 02:54 AM
mrwhos
Aug 11, 2015 02:03 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
