Alpine Time-Correction feature help
Old Jul 31, 2005
blouisgod's Avatar
Life Begins > 6800rpms
I've reviewed the manual, but which settings have provided the best sound? Im using a 7894 with
alpine type r tweets on 200w max front amp
factory 6.5 mids on deck 60w max
alpine type s 6*9 on 300w max rear amp
audiobahn aw120t vented sub on 1000w max sub amp
Im trying to get the sub and rear to gain a lil speed and / or slow the fronts down. btw, the bass focus is all to the rear. i probably just need to tool around with it.
Old Jul 31, 2005
MegaHurtz's Avatar
I think you can go onto alpines website and they have some software that will make your settings for you and then you can load them onto your deck
Old Jul 31, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
^^Yeah thats iPersonalize and it might not be available on his deck. I couldn't find anything in a minute of searching.
Old Aug 1, 2005
blouisgod's Avatar
yeah my model is from 2k3. its to old for ipersonalize but still works great
Old Aug 1, 2005
BassKadett's Avatar
That's what counts.
Is there a way to change your time correction measurment to inches? Then you could measure how far each speaker is from your head and then set it accordingly. You also could use the iPersonalize website to get the numbers you need since it converts it right there.
Old Aug 1, 2005
AlpineCivic's Avatar
You can still use the i-Personalize feature on Alpine's website. Just enter your measurements and it will tell you what to set the time on your deck.
Old Aug 1, 2005
blouisgod's Avatar
yeap figured it out. thanks for all the help.
Zygrene
Mar 22, 2016 12:36 PM
carid
Sep 28, 2015 10:13 AM
Donahue
Sep 8, 2015 09:00 AM
horta1212
Aug 22, 2015 08:31 PM
2005seTO
Aug 18, 2015 12:45 PM
