Alpine Type-S components question
Old Jul 21, 2005
Mendes03's Avatar
Mendes03 is an unknown quantity at this point
I installed some Alpine Type-S 6.5" components today. The tweeters sound great, the woofers sound very weak though. Wiring is all good. I have to fade my HU to the front to balance the output now....otherwise all I'm hearing are the tweeters and the rear speakers. Do I need to amp these? Let me know what you guys think.
Old Jul 21, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
Can you hear any sound from the woofer at all? Try listen to vocal and see if you hear a "complete" voice or not...If not, then lower your tweeter level on the crossover(if it has it, I have no idea on type-s's)
Old Jul 21, 2005
Mendes03's Avatar
It is putting out sound, just not nearly the same level as the stock speakers.
Old Jul 21, 2005
jb1004's Avatar
jb1004 will become famous soon enoughjb1004 will become famous soon enough
Are you running them off the stock head unit or an after market one?
Old Jul 21, 2005
82801BA's Avatar
Speaker sensitivity issue......Simply because stock speakers are much more sensitive than type-s's.....ie. those type-s are putting out 90dB/W/m, while I would say stock is at least 93, means you only have 1/2 the level from stock....
Old Jul 22, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
u need to amp those speakers 4 sure. they will sound like **** w/o the amp
Old Jul 22, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
I have the type x component. They had nice mid bass while testin them, but in the car, the tweeter sounds great, but mid is lackin. Could have the same problem as you. And i am running these off a rockford 200.2 amp
Old Jul 22, 2005
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
i want to know what the output of your head unit is. i know that you at least have to run those type s's on at least 26watts for them to sound good. if its not enough a simple 50wat amp will fix this try using one of alpine's lower end 4 channel amp.
my two cents
Old Jul 22, 2005
blouisgod's Avatar
Life Begins > 6800rpms
you have to put at least 100 watts to them to get them to move.
Old Jul 22, 2005
MegaHurtz's Avatar
type-s are more sensitive speaker, specifically designed to run off deck power. if they aren't loud enough for you, I dunno what the problem would be
Old Jul 22, 2005
MegaHurtz's Avatar
the output of the head unit won't make a difference, there isn't enough variance between power levels between head units (even between stock and aftermarket) for that to be an issue. unless the speakers have an absurdly low sensitivity rating, they should get almost as loud as the stock speakers at comparable volume levels... in fact i dont think you should ever even see a percievable difference... sensivity difference of 3db (90db vs 93db), might sound like a fair bit, but in practice it's like nothing, i doubt you would really be able to tell the difference and even if you could, it would not be a lot.
Old Jul 22, 2005
82801BA's Avatar
Turn DOWN your tweeter on the crossver!!.....I really don't know about Type-S, but Type-X, which has JUMPERS onboard of the crossover, you better do the tweeter into the lowest level (-3dB or -4.5dB or whatever, especially on the NEW, Made in China Vifa Type-X wave guide tweeters. The older Dennish made Scan Speak Type-X tweeters isn't that senstive). The tweeters will be very very bright if you install in sail panel(triangular panel covering the mirror) without turning down tweeter level....
Old Jul 22, 2005
MegaHurtz's Avatar
ya the tweeters are super bright, try -3db first then -6db (there are jumpers on the crossover). I have my hertz hi-energy tweeters currently attenuated by 3db... 0db is too sharp and 6db too dull, 3db is perfect for me, but keep in mind I am using different speakers altogether.
I remember somebody on this board at one time saying that they have only heard one set of tweeters that didn't need to be knocked down when installed in the sail panels (CDT if i remember correctly) and that included higher end drivers too
Old Jul 22, 2005
82801BA's Avatar
The way Alpine does their tweeter attenuation on Type-X is that, it lowers the level of upper level part of freq, such as 8kHz+. Anything between acoustic (not electric) XO point and 8kHz doesn't change. If that area is too bright, then sorry, nothing can help except a wide band EQ (Q=0.5) used at around 6.3kHz....
Old Jul 22, 2005
draganjr's Avatar
draganjr is an unknown quantity at this point
i just installed type s in my car running off the alpine 9851. i have the tweeters set on 0db and it sounds good, i do have to fader to the front @ 2 or 3. but i have no problems. also installed dynamat in the doors.
Old Jul 22, 2005
Mendes03's Avatar
I'm running these off of a Pioneer 7600. I'll try adjusting the crossover.
Thanks for the input guys.
Old Jul 23, 2005
Mendes03's Avatar
OK I adjusted the crossovers.........it's much better, the tweeters don't sound nearly as harsh. I'm still going to amp these speakers though.
Thanks for the help guys.
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
