Speakers...
Old Jul 19, 2005
steven10's Avatar
steven10 is an unknown quantity at this point
Speakers...
i have an 05 ex special edition so it has 4 speakers and 2 tweeters in the front.. i also have that head unit that comes wit it (MP3 6 cd indash PANASONIC i think) ... does anyone know what brand the speakers r?... also... if i wanted the bass to hit a little bit harder... wat type of speakers would i have to get?... i dont want subs cuz there too loud for me.. i just want this stock to hit a harder than it does now.. i like it now though.. just a lil bit harder ... =] any info would be great!
Old Jul 19, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
look in the first one u posted i put a reply in there
Old Jul 19, 2005
steven10's Avatar
what if im not planning to get subs?
Old Jul 19, 2005
booba5185's Avatar
then don't, u dont have to have subs, just get a nice set off 6.5s in the back if u wanna convert the back for 6x9s to 6.5 (cut a peice of wood into the shape....easy) and get a nice amp to power them, either way, components is the way to go.
Old Jul 19, 2005
steven10's Avatar
what do u mean when u say components?... im sorry im a newb... also... i would HAVE to have an amp? correct?...
Old Jul 19, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
go to walmart and get some pioneer 4.25 speakers for the front. get 6x9 speakers for the back. stay away from xplodes from sony. your speakers are stock honda speakers. if you want a harder hit, then get an aftermarket head unit that has at least 200 watts. more wattage to speakers will = harder hit. it won't always be clear if you turn it up but it will hit harder than stock. about the amp. you can get one for your speakers in the car. if you do get aftermarket speakers that can handle the power from the amp. also if you want an amp you will need an aftermarket head unit as well. components are your front 2 speakers and rear two speakers. those are kinda medium size for lack of a better word. tweeters are the two little speakers in the front of the car right above the dashboard. and subs are the big speakers. obviously. have fun
Old Jul 20, 2005
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
^^why 4.25? he can also get 5.25" or something cuz those will fit. if u want u can also put 6.5" speakers but its going to be hard fitting them in. i also read somewhere on this forum that the 04-05 speakers are low end pioneer speakers, i'm not sure on this but, can someone confirm this?
Old Jul 20, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Stock speakers are pioneers.
Front speaker size is 6.5
Headunits aren't going to do the power they say. 12-14 watts per channel rms is tops, stock or aftermarket.
More bass, best bang for your buck? JL VR coaxials, or Adire Koda 6's
Old Jul 20, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
6x9 generally gives more, but not better, bass (some midbass and a little sub-bass) and tighter by design because of the effective mass moving area is larger than a 6.5. But it really depends on what type of 6x9 you are using. You can get some 6x9's which are crap and sound even worse than a 6.5". Try to build a box or baffle to seal off the rear 6x9 if using it. It will give you much better response.
Old Jul 20, 2005
booba5185's Avatar
yea, good idea with the box and all, except for the trunk springs hitting practially any aftermarket 6x9's magnet
Old Jul 20, 2005
82801BA's Avatar
I know, but since I don't have rear speaker, I have no idea on how it will hit the trunk spring. Anyway, it's always OK to build a wider but less depth box.
Anyway, our cars are NOT built to build a quality sound system though. Remove the door panel ake a look at the front door.............................................. .
Old Jul 20, 2005
booba5185's Avatar
oh yes, i know i know, but there is no way to build a box with those springs, i've been thinkin of putting a trunk shock on either side and taking those springs out so i'd have more room
Old Jul 20, 2005
82801BA's Avatar
Then get a small baffle. It will help. BTW, don't forget the top space that you will get.
Old Jul 20, 2005
MajinB's Avatar
anyway, i prefer 6x9s. and yeah 5.25 would be fine too. just making suggestions. i wish to know how this will turn out. and yeah an aftermarket head unit don't push what it advertises-neither does any speaker or amp. but it should make it hit harder than stock head units. bostons are good but expensive. go with the walmart stuff. youll be fine.
Old Jul 20, 2005
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
they were pioneers?... omg.... i never knew pioneer made such crap.
Old Jul 20, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
1st off how much are you looking to spend? are you doing the install?
Old Jul 21, 2005
MegaHurtz's Avatar
Pioneer would have mass produced for Honda to meet their specs, these aren't like retail pioneer speakers that come in your car. Just becusae your stock speakers are Pioneer now you think Pioneer sucks? Your stock head unit (if you hvae the single din cd player) is Alpine btw, do you think Alpine sucks now?
Old Jul 21, 2005
Lots of amps do their rated power, and then some. All of JL's amps do their rated power, at any input voltage due to the regulated internal power supply technology. Lots of others come to mind to, but you catch my drift.
Old Jul 21, 2005
82801BA's Avatar
If it's Pioneer which made in Mexico then that specific Pioneer sucks. Just like Alpine mass produce Honda's CD player in Mexico, then that speicific Alpine sucks....
Old Jul 21, 2005
nick95673's Avatar
its a way for them to make an easy buck with tech from the 80's. at the end of the day the only thing that has to do with alpine or pio is the logo. this way all the honda salesman can say alpine. aand sale it to some girl who heard alpine is the best. its kind of like that awesome 6 speaker 200 watt pio system they were pushin in the tc it was still just a toyota sound system. and anyone who works in car audio knows infinity gold in dymler-chrysler is the worst.
Old Jul 21, 2005
82801BA's Avatar
How about those Dyn 3-way component speakers in Volvo? Shitty also?
Old Jul 21, 2005
nick95673's Avatar
most likely not too many volvo owners are into car audio. so i didnt really hear those. but think of it as a company whos job is to sale cars for the highest profit. if they waste money on audio equipment and pay to have it installed they then pass it on to you then they will charge another grand for the car or they can put a special edition sticker on it and charge 5000 more
maurofer90
Mar 9, 2015 06:51 PM
UnderDog
Jul 5, 2011 11:45 AM
MisterT
Jun 27, 2011 07:05 AM
steven10
Jul 19, 2005 09:20 PM
jerseysurfer23
Jun 23, 2002 01:44 AM
