How do i tell if myspeaker isblown?
Old Jul 10, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
I have the stock speakers in my EX COUPE.
just recently i noticed that the left speaker "burps" the bass. Like it sounds garbled and blurby. The tweets don't sound as crisp either.
The right side sounds crisp and regular.
Whats going on?
I tested this thoroughly by setting the fader to full left or full right. The left side definitely doesn't play the bass right and the tweeter doesnt sound as loud or clear.
Could thespeaker be blown? or maybe a pinched wire or something? whats the deal?
Old Jul 10, 2005
well its prolly blown then. usually blown speakers sound crunchy or don't play bass as loud as before. Open the door panel and take a look at the cone.
Old Jul 10, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
you could have bumped the grill and something could have hit the speaker or something. replacement aftermarket ones shouldn't cost more than 40 bucks. walmart pioneers. have fun
Old Jul 10, 2005
2k1civic.com O. G.
What signs of damage should appear on the cone if blown? i wil take it out tommorow afternoon to look.
Old Jul 10, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
one way to check is to take a multi meter and make sure they are still running at the ohm load that the components are meant to or very close to. if they are not they are blown.
Old Jul 10, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
It you can see tears around the surround, they're blown... turn the volume **** down.
Old Jul 11, 2005
robo_pimp's Avatar
robo_pimp is an unknown quantity at this point
if there are tears around tha surround, it doesn't mean that they are blown... i resently blew a mtx roadthunder 7500 sub at a car show and did i ever blow this sub... but yea... it sound is just distorted by alot.. its not clear and when tha bass hits it makes a noise like sumthing is touching tha dust cap when nothing is touching it at all.. but anyway... stock speakers suck so just buy aftermarket ones cause they just simply sound better. i a set of alpine type s coaxils for only 98 bux...
Old Jul 11, 2005
2k1civic.com O. G.
well i checked the speaker this morning, its not ripped. HOWEVER, the "woofer" doesnt seem to move in and out smoothly. When pushing it back it seems to make a weird scratchy / crunchy sound as if its rubbing on something. Is this normal? i thought a speakers "woofeR" is supposed to be able to move in and out without making any noise?
I tested some more and the tweeters sound the same on both sides, so im assuming its not a pinched wire problem.
I guess the speaker is blown but not ripped? haha anyone wanna send me their stock speaker for free? i will pay the shipping.
Old Jul 11, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
yes it is blown, that scratchy noise your talking about when you push it in is the voice coil that has seperated.
Old Jul 11, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Knowing whether a speaker is "blown" isn't found by just listening to it. The best way to know for sure is to put an ohnmeter to it and test for proper impeadence. A lot of times when the bass response of the speaker sounds distorted it could mean the speaker is out of phase (wires hooked up backwards) when you balance it right to left.
Old Jul 11, 2005
2k1civic.com O. G.
yea, thats probbaly true and i will keep that in mind.
but this is my stock speaker, and its been working fine for the last 4 years almost. lol. no changes in wiring at all!
Old Jul 11, 2005
Taffy's Avatar
Stock HU also or Aftermarket? If Aftermarket was installed recently, I'd double check the wires and harness to see if any of the pins were bent. If one of the pins are bent this will most likely make the speakers sound like ***.
Old Jul 11, 2005
2k1civic.com O. G.
aftermarket headunit. its been unmoved and untouched for almost just as long. like 2-3 years. im 95% sure the wiring and pins are making proper contact. but physically the speaker didnt seem "healthy".
I guess to double check this even more, i should check my passenger side speaker and see if it makes that same noise when i move the cone in and out.
Old Jul 11, 2005
stock speakers suck!
Old Jul 11, 2005
2k1civic.com O. G.
yea, im considering a set of eclipse components! i want boston pro's but its kinda expensive 300.00 bucks. 100 dollars more than the eclipse set i want.
