Speaker hissing when using satellite radio
Old Jun 27, 2005
mack82097's Avatar
mack82097 is an unknown quantity at this point
I have a 05 Honda Civic Coupe. It has the factory radio and the in-dash CD changer. I just installed a Soundgate docking station so that I could keep the CD changer and still directly wire my Sirius Starbase to the aux. input. It works great, accept that now when I listen to the CD changer or Sirius radio I hear a high pitched whine in the background. It's coming from the speakers and it's really annoying. When the engine is off, there's no noise. When the rev's increase, so does the noise. I tried installing a ground loop isolator, but it didn't help. I'm desperate at this point!!!
Any suggestions?
Thanks.
Colin
Old Jun 27, 2005
CivicStudEx's Avatar
CivicStudEx is an unknown quantity at this point
you gots engine noise....
Old Jun 27, 2005
mack82097's Avatar
Thanks. Now, how do I get rid of it?
Old Jun 27, 2005
i dunno, i'll bump this up, hopefully somebody will help
Old Jun 27, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
Old Jun 27, 2005
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
have any power wires running near/across speaker wires? That's a common way to get ground noise from an amp, might be something to look into.
Old Jun 28, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
is the cd changer and sirus tuner grounded at seperate locations?
Old Jun 28, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
alternator whine u definatly need to check ur grounds and make sure that they r seperate...
Old Jun 28, 2005
mack82097's Avatar
I grounded them together on the same part of the chassis. Should the grounds be in separate locations?
Old Jun 28, 2005
honda860's Avatar
honda860 has a little shameless behaviour in the past
yeah id say it most likly a ground issue. check your grounds on your amp and the grounds for the other connections. I dont think it matters if you ground them together or not because I did. Until I read your post better I thought cus you had it transmitting wirelessly. BUt im 90% its a ground
Old Jun 28, 2005
AlpJLFan's Avatar
AlpJLFan is an unknown quantity at this point
check and make sure your RCA's are plugged in and have good connection. Make sure the RCA's are not damaged. When you did your ground..... are sure you sanded away paint. Sometimes you make think its metal when its really paint. You would be surprised. Signal cables should be away from power wire.
your grounds shouldnt be in seperate locations. try and put all your grounds in one place. if you have grounding points all over your vehicle for electronic stuff, thats a common way to get engine noise. Do you have neons or anything? unplug those and see if you still get the problem
Old Jun 28, 2005
mack82097's Avatar
I have two ground points that I'm using for my accessories. What I'll do is consolidate all of them into on point and make sure that it's good and clean. Hopefully that'll fix the issue. I'll be sure to let you guys know if it does the trick. Thanks for all your help so far.
Old Jun 29, 2005
mack82097's Avatar
I found the problem. THe Soundgate unit was getting interference from the electrical wires in the dash. Once I moved the unit to a place under the center console, the buzzing went away. Thanks for all your help.
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Metalzone
Sep 16, 2015 12:33 PM
jpat21
Sep 3, 2015 11:32 PM
