Questions about Sub/Amp Matching
Old Jun 15, 2005
suthurnlatino's Avatar
suthurnlatino is an unknown quantity at this point
I want to get some MB Quart PWE 352 (or 354s if better) but I don't know which amp is better to hook them up. I am considering the MB Quart Reference RAA2400 2-channel car amplifier (200 watts RMS x 2 4ohms or 400 watts x 2 2-ohms or 800x1 4-ohms min) or the MB Quart Reference RAA1000 (250x1 4ohms or 500 watts x 1 2ohms or 1000 watts RMS x 1 1ohm).
I tried reading topics in other forums on the speakers but they only confused me more since I am a noob at car audio. What I thought is that I would be unable to get 800x1 RMS from the RAA2400 since it is 4 ohms minimum and the PWE 352 is 2 ohm so I should go with the PWE 354s which are 4-ohm component speakers. That's the best set up I could figure out but I would appreciate if someone with better knowledge of car audio could help me out.
Old Jun 15, 2005
MegaHurtz's Avatar
get the RAA1000 and whatever subs will get you a 1 ohm load
if the subs are dual voice coil, get the dual 4 ohm version and wire it in parallel/parallel.
Old Jun 16, 2005
Thanks for the suggestion but I was hoping to get the Subs moreso than the amps. The MB Quarts subs are marked down to $120 (2ohm) and $150 (4ohm) which is why I wanted to hop on them while they are cheap.
Old Jun 16, 2005
MegaHurtz's Avatar
the amps are good too and its always nice when your equipment all matches
martinsmartin
Aug 15, 2015 07:34 PM
JetsterDajet
Aug 15, 2015 08:07 AM
spyder13
Jul 31, 2015 06:31 PM
sch2cm
Jul 21, 2015 09:58 PM
