AMP & Sub Hookup Question
Old Jun 10, 2005
theeCivic's Avatar
theeCivic is an unknown quantity at this point
I have this amp, these subs, in this box. (Sites for illustration only.) Not too educated with the technical aspects of the amp/sub hookups, but am a real smart guy. There is no manual for the amp since it was made a while ago.
What is the best way of hooking all of this up and getting the most out of it. I know it's not much, but it's what I have for now. I have another amp if hooking wach sub to an amp would help, different brand though, so I think it would sound different. Any help is appreciated.
Old Jun 11, 2005
southwest713's Avatar
southwest713 is an unknown quantity at this point
4-channel amp, 2 single voice coil 4ohm subs. bridge 2 channels of one amp for 1 sub then the other 2 for the other.
Old Jun 11, 2005
theeCivic's Avatar
Thanks man, yeah I was thinkin of only using the rear L & R, but then I was reading that I should do what you said brigde the L&R of the rear, and L7R of the front, as long as I have the high pass & low pass right on both front and rear it should be ok, do that sound correct? Will I get better results with that than just using the rear channels? Thanks again.
EDIT:
Or are you saying to use both amps. I've been reading and for sure the eclipse one is better than the other 200w amp, should i still use both, one for each speaker and just adjust the gain so they both sound equal, or do the above with the one amp?
redcloud
25
Aug 12, 2015 01:23 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
