wiring the ground
Old Jun 10, 2005
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
wiring the ground
ok, i have 3 grounds going to a distribution block, 2 are 4 guage, 1 is 8 guage. i was told that since i have all that going to a dist block i should get 0 guage to go to the chassis. well i though this up, what if i ground the dist block to the chassis by using 2 4 guage wires. would this increase my resistance? or should i be able to get away with 1 4 guage to chassis?
now heres where i tell what i have cuz i like to do that. i have a jvc khd700 head unit, the 6's and 6x9's are planet audio being powered by a soundstorm 800 watt 4 channel amp. i have 2 audiobahn 12" aw1206t subwoofers in a p4s ported enclosure, powered by a hifonics brutus 2005d monoblock, sending 2000w rms. i also have a pyle 6 farad cap. stock battery and alt. i would like to someday toss the audiobahns and get some mtx9500's. and i dont know about that cap. i should take it off and see if there is any difference.
Old Jun 10, 2005
sador's Avatar
sador is an unknown quantity at this point
Leave the cap in there, about ground you can use the 2 4 gauge and make a thicker cable but why you don't buy a 0 gauge wire you just need at least one foot, plus remember the the shorter that the ground is the better gonna be and also clean where you gonna connect I mean no paint or ETC...and make sure it's tight.
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
