that rear deck rattle !!!!
Old Jan 25, 2002
hose2k1's Avatar
hose2k1 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] what am i to do i have tryed to figure out where that rattel is coming from(in the rear deck). its there when the bass hits and its there when i hit bumps or drive on these unsmoove new york city roads im taking my trunk apart until i find the problem if any one has any other ideas it would be really helpfull. i have read other opinions but i just dont understand. if anyone is a specialist in sound deadiner then teach me cause i need to know[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 25, 2002
sivic2k1's Avatar
sivic2k1 is an unknown quantity at this point
i had the same rattle, just tightened every bolt i could find, now just hear it once in a while...
Ma$e
Old Jan 25, 2002
hose2k1's Avatar
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG] thanks im a try every thing see what happens if any one else got an opinion lemeeno.
Old Jan 26, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
Had similar probs coming from the rear deck............I tightend every bolt I could find, and I dampened the rear deck and the side panels, and haven't heard a rattle since. Good Luck!!
Old Jan 27, 2002
Brian's Avatar
Brian is an unknown quantity at this point
I cant find it now, but there was a tech bulletin (i.e. known issue) issued to Honda dealerships specifically regarding the rear deck rattle. Talk to your local dealer, they fixed mine for free.
Brian
Old Jan 28, 2002
Kion's Avatar
Kion is an unknown quantity at this point
rolled up a few paper towels bout the size of a wallet and shoved it in between the deck-brakelight lens and the chassis frame itself, problem solved in less than 2 minutes total hehe
oh, and i just did that to my boy's a4 and fixed his rear deck rattle too, 2 minutes, hehe
Old Jan 28, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
mine doesnt rattle
Old Jan 28, 2002
Grey's Avatar
DIY King
I think someone mentioned that the rear deck hits a piece of plastic covering the seatbelt anchor? Mine rattles a little bit too with certain bass frequencies. I'll have to open up the rear deck again later on and check that seatbelt thingie out.
Old Jan 28, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I used insulation tape around all of the areas on the rear deck that make contact with the metal. It really helps, though there is still some rattle over bumps. When I put new 6x9s in the back, i could not use two of the pop rivets on the outside close to the window.
Old May 6, 2002
dragoon's Avatar
did you happen to miss the 2 bolts holding on the rear deck? I did gonna put them back in today *sigh*
also, would it matter if one of those weird plastic clips that you can see when you put the seat down goes missing? they don't seem to do much.
Old May 6, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
What two bolts are you talking about? Only white plastic clips here[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 6, 2002
kempster's Avatar
kempster will become famous soon enoughkempster will become famous soon enough
Today as i was driving home i lowered my radio and asd the bass hit i heard some bad rattling it sounded like a piece of metal was vibrating and i must of spent hours ripping my car apart trying to figure out what was going on.
Old May 6, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
ya it drives me nuts too. I figure when I have some more time (ie summer) I'm thinking of dynamating my trunk, for now I buckled all the rear seat belts so they wouldn't rattle. Something this simple only takes a few seconds and cuts down on the rattling a little bit. + I think it looks a little bit better.
Old May 6, 2002
dragoon's Avatar
maybe 'cause I've got a 2k2, but my rear deck also has 2 screws that hold it in. and all that stuff really did help eliminate the rattle!
oddtodd
Detailing
Aug 23, 2015 03:03 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
Yazan93
Jul 14, 2015 08:56 PM
