Upgraded to JL 12w6v2
Old Jun 8, 2005
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
i dunno what to do???...
this is what i got right now,
JL 12w3v1
Precision Power PCX-1250
1x250watts @4ohm
1x500watts @2ohm
i came across a very good deal for a JL 12w6v2....
i'm getting sick of the single 12w3, it's just not enough, the SQ isn't quite there and the SPL isn't enough either.... so i KNOW that i will eventually get something better....
sooo, how do you guys think it'll sound with the Precision Power amp??
i might be able to get the guy to lemme try it out in my car.
Old Jun 9, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
i sthe sub a dual or single voice coil? What are you running now. If you match up your ampa nd sub and tune it properly it may sould great. if the w6v2 is a dual 4 ohm then you will run at 2 ohns and run 500 watts. if you have a single dual coil now running at 250 watts then you may not get teh sound that you want. If the ohmages are the same i don;t think the 2 subs will sound all that much different. Thats just my .02 though. Goodluck post again if you ahve any more questions.
Old Jun 9, 2005
BlueTroll's Avatar
the 12w6v2 is a dual 4ohm sub...
i was definitely going to wire it in a 2ohm state.... give that baby 500watts of clean power...
the 12w3 i'm using now is also a dual 4ohm.... i'm giving it 250watts@4ohms.
Old Jun 9, 2005
Umm its impossible to run yoru dual 4 ohm sub at 4 ohms unless you are only running one voic coil. Run it at 2 ohms. I think the subs will sound very similar. try it out but i don;t think its worth it.
Old Jun 13, 2005
BlueTroll's Avatar
so i ended up getting th 12w6v2...
omg... what a great investment... SQ is amazing even at high volume....
it kinda makes me want to cry.... haha....
i've finally unleashed the TRUE potential of my PCX-1250....
the PCX-1250 is the Beauty and the 12w6v2 is the Beast... or the other way around.
Old Jun 13, 2005
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I also upgraded my 12w3v2 to a 12w6v2v accidentaly, thought that my w3 was blown out, but it turned out to be my amplifier. I ended up buying a slightly powerful alpine amplifier that pushes about 400W RMS compared to my previous amplifier that pushed 350W RMS and I found a big difference in the quality, especially at high levels.
Old Jun 13, 2005
BlueTroll's Avatar
i've only listened to the sub for half a day... and it's beyond my expectations....
Old Jun 13, 2005
TiM3's Avatar
TiM3 is an unknown quantity at this point
I've had my 12w6v2 for about a month as well and I love the quality of the bass. I'm powering mine with the JL 500/1.
However, I want two 10w6v2's. So if anyone's interested in a one month old 12w6v2, I could give you a good deal.
Cam Diaz
Sep 29, 2015 07:17 PM
AffliictiioN
Sep 16, 2015 02:21 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
KikAzz
Sep 4, 2015 12:36 PM
