Sub, amp install on stock car help.
Old Jun 4, 2005
Ed's Avatar
Ed
Well, i've been working on this all day..
I just wanted to put a small sub i had laying around in my sister's car. It's a single JL 8w3 in a small ported box. I got an MTX 282, two channel bridgeable amp to power it. I wanted to tap off the rear speakers connected to the speaker level inputs on the amp. The amp should be able to turn on automatically when it sees a signal.
Even if i jump the remote to the power wire, it will turn on, but there's still no signal.
I get it all hooked up and there's not sound from teh rear speakers, and the amp doesn't turn on. If I unplug one of the speakers momentarily, then plug it back in, the speakers will start up ans so will the amp, then all is good.
It's a new Toyota Camry. It seems like the HU knows when i have something onnected to the rear speakers, and won't send anything to them.
I also tried making a crude line level converter with some 1k and 10k resistors as a voltage divider and tried connecting it to the RCA inputs, but still the same problem. Any ideas??
Thanks!!
Ed
Old Jun 4, 2005
LudlamTheory's Avatar
i boogie for the raindrops
im curious... do you have to remove both poles from that one speaker you have to plug/unplug, or just one?
Old Jun 4, 2005
okay, i have a test for you to do for me
if this works, i have a simple solution for you
unplug the + off a speaker while the radio is off
turn on radio with wire unplugged
plug in wire
see if it works...
or, does it have to be turned on, THEN unplugged, then plugged in to work...
Old Jun 4, 2005
Ed's Avatar
Ed
That works, leaving it unplugged, then turning it on and then plugging it in.
Are you thinking possibly a relay connected to a switched signal switching the + pole of the input?
Thanks for the thoughts!
Old Jun 5, 2005
www.davidnavone.com has a piece for 19.95 that delays the relay turn-on for up to 2.5 seconds...
the same thing could be built for 5-6 dollars at radio shack (resistor, capacitor, relay)
Old Jun 5, 2005
Ed's Avatar
Ed
Hmm, that looks interesting. I think i might have to do something like that, i think it's her that's kind of finicky. I might try build one, just for fun
Old Jun 5, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
The cheaper adapters are exactly wat they are cheap. you will lose sound quality. It may not be enough to warrent anyone caring but a good one wold be the jl audio hi lo adapter but it sells for $400
Old Jun 5, 2005
Ed's Avatar
Ed
It's only for a sub, so I'm not worrying about it too much.
Old Jun 5, 2005
you shoudl be fine then. Good luck with everything.
Old Jun 8, 2005
just out of curiosity ed, whatd you end up doing?
Old Jun 8, 2005
alex053's Avatar
this was a problem with some factory systems when i worked at mtx long long ago. just spend the bucks on the LOC.
Old Jun 9, 2005
Ed's Avatar
Ed
I haven't gotten around to doing anything with it yet, since I left for school.
Alex, if you think a LOC will do the trick, I think I might go ahead and pick one up.
Thanks everyone, I'll update the thread as I get it working [hopefully ]
roverben
Jan 21, 2019 05:16 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
smmahan
Apr 15, 2015 08:17 PM
