Alternator Whine!
Old Jun 1, 2005
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
Alternator Whine!
So I redid my system and now I have horrible alternator whine. I had a trace amount before, but now it is unbearable. I was wondering if anyone has any ideas on what it could be OTHER THAN interconnects, proper ground....all the common stuff. All of that has been checked and it is not the source of the problem. Any help would be appreciated...Thanks.
System specs in case you need them:
Pioneer DEH-3600
MB Quart RCE-216's
Phoenix Gold x100.4 amp
Phoenix Gold x600.1 amp
0 gauge power and ground
12 gauge speaker wire
If you need any other info ask.
Old Jun 1, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
OK these may be your problems. I am a tard in some aspectys of sstereo stuff and good at others. If you are running your rca's along with your power wire that is your problem. if youa re using crappy rca's that coudl be a problem. Also try to ground your car better. this is for an Si but it may helpo. http://www.k-series.com/tech_detail....P_GROUND_WIRES also... search for grounding here there is an FYI somewhere. If you have any other questions ask away.
-Matt
Old Jun 1, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
What kind of rca's do you have?
Old Jun 2, 2005
Ed's Avatar
Ed
possibly try turn your gains down.
Old Jun 2, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I think Ed is spot on with at least the first thing to check. I think Gains are becomming the number 1 cause for whine. Just seeing it a lot lately. So, Check that. then Check your ground. I know you said you did, did you try moving it though? Then check your cables for a breach. You may have breached them when pulling them through a tight space.
Old Jun 3, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Uhr?
I've never heard of this before, but it makes sense. Does this mainly happen on newer, high-voltage RCAs?
Old Jun 4, 2005
Titleist71's Avatar
Pioneer DEH-3600
MB Quart RCE-216's
yes the bearings can go in them...mine went when I had like 3k miles. started whining really loud..I took it in...used no accessories and made sure to drive during the day. New civic alt with install and under warranty...$500.
Old Jun 5, 2005
I got rid of the problem. It was actually the RCA's that run from the 4 channel to the mono that was causing the problem. I went and picked up a set of balanced RCA's and ran another set from the HU to the mono amp. All good now.
Old Jun 6, 2005
ex_03's Avatar
Godlike member
rca's huh!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
