Battery Drain Troubleshooting Question
Old May 21, 2005
bearbon's Avatar
bearbon is an unknown quantity at this point
My 94 Civic battery was going dead after a few days parked. I was reading about .4 amp drain with everything off and ignition key removed. The logical thing was disconnecting all the alternator connections - still had the drain. Started pulling fuses and drain went to zero when I pulled the fuse for the back-up lights. Where is the back-up light switch and how hard is it to get to? Also, is there anything else on that circuit? It's obviously not a dead short but a resistive leak somewhere in that fuse circuit. I don't have a schematic. Thanks, Bearbon
Old May 22, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Do you have anything aftermarket installed...ie, remotestart alarm?
Old May 22, 2005
WhiteRabbit's Avatar
did you reconnect everything else to ensure that it was exclusively that causing your drain?
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
viper775
Dec 9, 2001 10:52 PM
