EX Tweeters on LX
Old May 16, 2005
c.nightmare's Avatar
c.nightmare is an unknown quantity at this point
Question EX Tweeters on LX
Got a question here. Anyone tried to install Factory EX Tweeters on an LX?
Both coupes.
I got a pair of factory Ex tweets and figured that it was probably just Plug N Play. Guess not. No wire harness/plug in the LX door.
Do I need to manually go in a splice cables? If so, do I connect right off of the door speaker cable?
Old May 16, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You won't be able to add tweeters to a factory system if your car came with coaxials in the first place. YOu would need a xover that woudl accomodate the tweeters to send the right freqs to it. If you splice in your coaxials wires you are going to send a full-range signal to your tweeter and fry it.
Old May 16, 2005
[QUOTE=J187]You won't be able to add tweeters to a factory system if your car came with coaxials in the first place. YOu would need a xover that woudl accomodate the tweeters to send the right freqs to it. If you splice in your coaxials wires y
Then, can i get a Xover from an EX and install it? I have an Alpine HU with all stock speakers.
Old May 16, 2005
ToX's Avatar
ToX
ToX is an unknown quantity at this point
He doesn't the LX come with tweeters already???
I have a 01 coupe lx and it has tweeters stock
Maybe its a canada thing
Old May 16, 2005
Rennen's Avatar
New Mod on the Block
hey... howcome my 03 EX sedan didnt come with tweeters?
Old May 16, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I know some aftermarket tweeters have a tiny crossover built in to filter the lower end - not sure about honda stocks. You'd have to know the manufacturer and get a model number to find out.
Old May 16, 2005
J187's Avatar
I think Honda uses the headunit to cross em' IN that case, You would have to get a HU from a Civic w/ stock tweeters and you'd be better off buying a new HU After market. But the point I am making is, if your car did not come with tweeters, you wouldn't benefit at all by adding them. Tweeters in component speakers are only there because the Larger woofers play the lower frequencies and the tweets play the higher. IF you do not have stock tweeters it is because you have coaxial speakers designed to play both high and low and if you add a second source of high frequencies it'll sound like ****.
Old May 16, 2005
fonto's Avatar
The LA Clipper
I think the EXs had an inline filter for the tweeter, and full range went to the mid in the door. They prolly just let the mid rool off on its on.
Old May 17, 2005
lowther420's Avatar
lowther420 is an unknown quantity at this point
Tweeters
Tweeters only come on the Canadian SiG -(American EX Coupe)
Old May 17, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
^^ I don't think thats entirely true. Didn't Mega get em stock on his LX?
Old May 17, 2005
ToX's Avatar
ToX
I just said I have them stock on my 01 LX
Old May 17, 2005
Bires's Avatar
Bires is an unknown quantity at this point
That is the case. There is a little capicitor inline about 6" before the tweeter. There is no separate wiriing in the harness for the tweeter.
(...at least not in my 02 coupe...)
You should be able to splice them into your wiring in the doors.
This begs the question, then...WHY? The stock tweeters are not very good, unless you are on a zero-dollar budget.
Old May 18, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I have an 02 lx, and i put the ex tweeters in my car. I just spliced the wires +/- accordingly for the below speakers and it works fine.
ZoSoIV
Sep 17, 2015 07:17 PM
Jeffdp
Aug 5, 2015 11:38 AM
STang57
Aug 2, 2002 07:59 PM
TroyA
Jul 7, 2002 10:18 PM
