second battery problem
Old May 8, 2005
alpinecivic02's Avatar
alpinecivic02 is an unknown quantity at this point
I just installed an isolator in my car to run two batteries...i want the one in the back just to run the system however....i have an optima red top in front and a stinger yellow in back...my problem is the battery in back wont keep a charge...it just keeps dropping voltage....im pretty sure it's my stock alternator not being able to keep up....however someone let me know if there's nething else i can do...also my alternator charge light flickers everytime i change gears everyonce and a while...but the car hasnt died on me so i know the front is getting a charge....and it has been a week
Old May 8, 2005
MegaHurtz's Avatar
maybe the isolator is giving you too much loss and the rear battery cant charge on the voltage it's getting... supposedly isolators drop approx a full volt across the terminals, so you might want to try something a bit more efficient. Try an RV solenoid
Old May 8, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
you dont even need an isolator. I been running mine for long time with no problem
Old May 8, 2005
civic2004's Avatar
civic2004 is an unknown quantity at this point
get a bigger alternator or rewire the one you already have. Also check your voltage regulator. That might be causing a problem.
Old May 8, 2005
civic2004's Avatar
Myself I think I need an Battery Isolater. I have blown out the voltage regulator twice already.
This is what I'm running:
http://www.7thgencivic.com/forums/sh...d.php?t=211349
Old May 8, 2005
WhiteRabbit's Avatar
check your regulator with a circuit checker. should work one way but not the other.
Old May 9, 2005
Havok2k1's Avatar
Wicked Pissah Admin
If your light's coming on at all, you need an alternator. I give it a month.
Old May 9, 2005
well the alternator is brand new...but where would i go to rewire it or make it a stronger amp
Old May 9, 2005
civic2004's Avatar
If you have enough room for a bigger one, just get a new one. If you don't you can rewire it like I said before. Just go to any alternator place and ask if they rewire alternators. Where in cali do you live?
Old May 10, 2005
thanks man i called around and found a shop wthat will rewire it...so i willl try that...thanks
Old May 11, 2005
Inferno333's Avatar
Inferno333 is an unknown quantity at this point
Anyone know a place in Iowa that does alternators?
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
