cant get my system to work
Old May 4, 2005
1sickhb's Avatar
1sickhb is an unknown quantity at this point
i have a all alpine system 2 12" type s subs 2ohms with a mrd-m500 amp pushes 900 wats i also have a cda-9853 head unit 05 modle new i got the alpine type s rear speakers and front but i have it all hooked up my amp turns on and everything all my wires are hooked up right iv talk to everybody best buy ect and i tryed what they said and it wont work i get power to my amp but my subs wont play or do anything and i dun no what the prob someone help me
Old May 4, 2005
Rennen's Avatar
New Mod on the Block
are you sure that your amp is getting a signal from your headunit? maybe you connected the rca's to the wrong outputs...
Old May 4, 2005
Farage's Avatar
I like you! do you like me?
chances are its the remote wire
Old May 4, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
check ur remote wire from the HU. Also, check that no wires on ur door speakers are touching metal, decks have a safety feature on them and wont play if thats the case. Check ur fuses too just in case u blew one if u have a distribution block. Check the voice coils on the subs and make sure they're hooked up right. Check the deck itself, if it has a sub input, make sure the level is adjusted, or turned on. Make sure the RCA's are in the right spot. good Luck
Old May 4, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
it can't be the remote wire because he said that the amp turns on. Like umysugarmami said, it's probably the RCA's. On amps, you usually have the input and the pass-thru output to connect another amp, make sure you put it in the input. Also, on your HU, your sub-out maybe turned off. Go in your function menus and check if the sub output is on
Old May 4, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
If after that ^^^^ doesnt work, then run a set of rca's from your amp(in the car) to a radio on a bench, and see if your amp works.
Old May 4, 2005
Rennen's Avatar
i doubt that it is the system wire b/c he said that the amp turns on.
Old May 4, 2005
chrisavs's Avatar
chrisavs is an unknown quantity at this point
also make sure u have power to your speaker terminals... get a DMM and check to see if 12V are running through the speaker terminals, but yea i'd say rca's are your problem
Old May 4, 2005
mikenam's Avatar
mikenam is an unknown quantity at this point
on my alpine 9833 i needed to turn on the subwoofer. Make sure the amp is set to lowpass freq.
Old May 4, 2005
MegaHurtz's Avatar
heh
its not the remtoe wire, the amp turns on
the deck will not protect if there is a short, the amp will
there is no fuse problems, becasue again his amp turns on
check to see if you are getting signal
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
