Amp Placement
Old May 2, 2005
zackde's Avatar
zackde is an unknown quantity at this point
Amp Placement
guys,
any bad effect if ill mount my amp on the top of my SUB box enclosure?
thanx
Old May 2, 2005
diskreet's Avatar
if its a cheap amp it might shake the control ***** thats about it. Or if really cheap it might break it.
you could always do this:
just zip-tie and screw in (the top) a piece of thin wood against the back of the seat...pull the cloth cover over and screw on the amp. Much cleaner and nicer if you ask me. not nearly as messy!
Old May 2, 2005
zackde's Avatar
thanx, i will do that
Old May 2, 2005
diskreet's Avatar
sure here is high res pic of what i am talking about:
If this helps please give me rep! I need it!
To get the fabric up like that just unzip both sides, on the very bottom there is also a plastic thing that i cannot describe but its not tight + doesnt hold too well, just try to tuck that in before zipping back up when finished and it will sit and zip better since its stretched flat. If you do not understand this part just go check out the seat back and see what I mean!
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
