Stock 2005 special edition civic sound system HELP!
this is the problem im having... i want to keep my stock speakers and stock speakers (6)... and my stock head unit..... all i want to do is add an amp and 2 subs... how could i do this? ... or better yet... what amp and subs would be good for this?... should i power the speakers through the amp?... or just the subs?... ima newb and i need advice... plz help!
power inverter... or adapter, i forgot what its called, its like a $50 device...find a local shop and ask them.
and i thought the special edition head unit has sub outs in the back? no?
I don't know much about the SE specifically, but in general, here's what you'll need.
You'll need to run a power cable, in addition to a switched 12+ wire to use as a turn-on lead for the amp. Then, ideally, you would use an amp that has speaker level inputs, so that you don't have to worry about a line level converter. If your amplifier does not, you'll need to buy one of those things he was talking about above, a line level converter. It will connect to the rear speakers, and come out with RCAs for the amp.
Either way, you'll need to splice yoru rear speaker wires for a signal. Then, pop in your subs and you should be ready to go!
To really help with your amp and sub selection, we'll really need some more information, such as your budget [including installation?], and the type of bass you're looking for, what kind of music you listen to, etc.
it's called a hi/lo converter if you are gonna stay stock stereo, cuz i almost did, but i said f--k it and bought an aftermarket stereo. JL's are good subs, a lil pricey, but good. JL amps are pretty good also.
im not sure if it had pre outs but ill see... im thinkin bout goin kicker.. i listen to hip hop... R n B.... linkin park... ummm.. pop... pretty much anything... but i want more of the hip hop dr dre type beats to hit.... i like my sound system right now... i just think it needs more bass.... i dont like it where the bass is louder than the song and thats all u hear.. but i want the bass to be there... for both amp and subs.... the most about 500... also installation would be done by best buy or circuit city so that doesnt count in the 500 im tryin to spend....
take ur car to best buy or cuircuit city, buy your stuff there and they'll install it for free, u don't have to worry... personally i'd go best buy, they are better imo...i've had better experiences with them
if you want to keep the stock head unit, you can. get a product that will convert the speaker level signal to a low level signal (low level = RCA), and then run it into your amp. Find an ACC power source and run a remote line back to the head unit to turn the amp on/off
Just splice off your rear speakers and run it to the line convertor. There are 2 good products that I can think of that you can use. One is from JL Audio called the Clean Sweep, the other is from Phoenix Gold and is called the SLD44. Both products will work very well, however I am not sure if either have them have made it to stores yet. I don't think the Clean Sweep has, but AFAIK the SLD44 from PG was just shipped out to dealers either this week or last.
Local audio shops will do a much better job.
I really don't think those high end line level converters are really worth it for his application, amping only subs. I doubt there would be too much difference atleast. I think those units are more geared towards the entire frequency range.
You should be alright getting stuff from Best Buy/ Circuit City, you won't need too high end/expensive stuff to drown out the stock speakers, so you should be good to go.
Electric Boogaloo...
In this case, a budget instal, The Cleansweep, the PG product, Audio Control's LC6, etc aren't necessary. A simple line-out/hi-level control will provide the adequate product to get the job done. Ask yourself what does the budget tell you to do. For budget install, I'd recommend a single Adire Shiva (assuming you can find one) and a JBL bp power series amp.
bestbuy is shiti work for circuit city installin car audio wat u need to do is upgrade everything. dont keep the stock speekers if u wanna run an amp to then cus u will blow them speekers in a week.Subs i say do 2 kicker L7's u can also do aKicker amp. u will need to change that radio unless u wanna keep buying hi/lo level converters cuz they go bad often.
"I want to keep my stock speakers and stock speakers (6)... and my stock head unit..... all i want to do is add an amp and 2 subs... "
Two L7s would completley drown out his stock system. He should stay more modest and look for a sub with great low freq extension that won't be ridiculously overpowering - like the Shiva suggestion but Ireally don't think you'll find one.
You could try CDT's subwoofers and let me know how they are - I've been dying to find out.
gabrown2
Apr 11, 2015 08:22 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
