16 gauge cable ok for grounding??
Old Apr 26, 2005
NoiSe's Avatar
I just went to Radioshack and all they have is 16 gauge cable.. I need to ground my capacitor, so will that do? It's only a short piece, around 12-15"
Old Apr 26, 2005
MegaHurtz's Avatar
absolutely 100% NOT!!!!!!!!!!!!!!!!!!!! and in case it comes up, several pieces of 16 gauge will not work either.
go to an audio store and get the same size that you are running from the battery to the cap and use that for your ground. don't cheap out or go half assed
Old Apr 26, 2005
ajhdragon's Avatar
7thgens official a$$hole
^^agreed
Old Apr 26, 2005
NoiSe's Avatar
lol.. yea, I figured, I just wanted to make sure..
I don't know if they'll sell me a piece that short though
Old Apr 26, 2005
ajhdragon's Avatar
im pretty sure circuit city sells it by the foot or something.
Old Apr 26, 2005
MegaHurtz's Avatar
everybody sells wire by the foot, it comes in spools and they just cut off what they need
if anything, the shorter the better becuse if you buy more they always give u a little extra and in turn lose some money, but with short you will get exactly what you need
go buy like 3 feet and a couple ring terminals
Old Apr 27, 2005
tripledoublegs's Avatar
Euro-Spec
HELL NO!
I would say 8 gauge for ground.
BTW, even walmart has 8 gauge wire, why do you go to radio shack?
Old Apr 27, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
8 gauge?? why would you assume 8 gauge??
Megahurtz is right. You should get ground wire that is eqivalent size to the power wire you are running. Nothing wrong with 8 gauge. If your running 8 gauge power, get 8 gauge ground wire.
Yes they should sell you 3ft of ground wire. If they don't, then I guess they're trying to be dicks. It is recommended to use 3ft or less of ground wire. You really don't need more than 3ft of ground wire. If you do need more than 3ft of ground wire, you need to get some help, and get someone else to install your audio. The reason I say this, is the fact that there are so many grouding locations you can use.
Old Apr 27, 2005
jttegx's Avatar
OMNES AD UNUM
check out the yellow pages and try to find one of those family owned car audio stores. 4-gauge wire goes from $1-$2 per foot depending how good it is. and 8 guage should be around 75 cents-$1.25.
goodguys sells monster cable by the foot as well.
get whatever size your power cable is. then get 3-5 feet of another.
Old Apr 27, 2005
NoiSe's Avatar
it was the closest store to me at the moment.. but yeah, I will look for it somewhere else, because the power wire is 4 gauge
thanks for the replies guys
Old Apr 27, 2005
NoiSe's Avatar
lol, no I def don't need 3ft.. it's 15" at most, if that..
Uan
Aug 23, 2015 03:03 AM
JetsterDajet
Aug 16, 2015 01:56 PM
BrandonD
Aug 9, 2015 10:22 AM
Dave1984
Jul 22, 2015 06:10 PM
muttleytm
Jul 11, 2015 06:00 PM
