noise from new speaks?
Old Apr 25, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Whats up guys.
On friday i had some components installed at a local shop. Everything was all gravy on friday night but on saturday as i was cruisin around I started hearing a wierd noise coming from the tweets. It sounds like a slide whistle that clowns use lol. whenever i push the gas it sounds like its winding up, a real high pitched sound, then when i let off the gas it sounds like its..winding down i guess. so if i rev the engine its all "weeEEEEeee." also, if i turn down the volume all the way i hear a buzzing noise from the front speakers. Im taking it back tomorrow to have them fix the HU relocation they did - and i'll have them fix the noise, but i was just wondering what this could be coming from? BTW do you think it could be coming from low grade RCA's? because they sold me a hella expensive kit and said it was the best and i'd be so pissed if they charged me up the a$$ for a crappy kit.
notes:
what causes tweets to have a high pitched whistle sound that is activated when i push, and let go the gas? also, buzzing coming from the front speakers when volume off.
Old Apr 25, 2005
eye_see_you's Avatar
let the devil out
alternator whine is what you have I believe. change to better rca's make sure they are not right beside your power wire or put on a filter
Old Apr 25, 2005
better RCAs?! fock i hope you're wrong! i paid $107.00 for the amp kit they put in, when i asked why they're charging so much more than other places around town they said cuz they use the best RCAs etc etc. well, either way they're going to fix it *i hope*
Old Apr 25, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
what kind of amp?
Old Apr 25, 2005
a kenwood excelon running the sub and kenwood 800w running the components. the 800w amp was running my old sub - so i know it works fine.
Old Apr 25, 2005
let the devil out
ok what kind of rca's did they put in that high priced kit
Old Apr 25, 2005
2K1Civic17"Gabe's Avatar
check the ground, or reground it. Make sure they shaved the paint off, lol. You have distortion somewhere in there. I doubt you need new RCAs. It could be the power wire/RCAs are running on the same side of the car, but Ive never had a prob with that. I changed mine to be seperate anyways, but I doubt thats it. Check your grounds. Turn down the amp some, asjust any crossovers. They RARELY do any of that at regular shops.
It was probably cuz somebody else installed it. No matter how little or big, ALWAYS DO WIRING YOURSELF! You can do other peoples and whatnot, but honestly, I wouldnt ever let anybody do your wiring, especially a shop.
Old Apr 25, 2005
would i sound like like an a$$hat if i said i have no clue...they said they were better...so i believed them....
but in my defence - they're regarded as the best place in town. they always do quality work so i don't know what happened here...
Old Apr 25, 2005
Oh yeah, and always use Monster Cable. They are one of the best, lifetime warrantys on most or all their stuff I believe, and decent priced. Well, somewhat expensive, but Im happy very with my Monster Cable parts.
Old Apr 25, 2005
Its all good. I used to know nothing about stereos/electrical.
Ive had Best Buy install, take out, reinstall a system before. Ive had Audio Express install a system, and alarm. Everytime, you can see all the wiring, they dont set anything up, they cheap out, dont even have connectors for the amp. They looked at me like I was crazy when I asked for some. They're like, the right way to do it, is just twist the wire up, and stick it in there. Im like, uhhhhh, thanks for letting me know to NEVER use you guys again.
Old Apr 25, 2005
the one time i tried installing my own HU everything was all good - for a couple hours. then my battery died. haha so im scared to mess anything up with wiring sound stuff.
Old Apr 25, 2005
CivicStudEx's Avatar
CivicStudEx is an unknown quantity at this point
i had engine noise and I believe I had Monster cables, my brother always uses them. so he got this adapter that pluged into the RCA's then into the amp. killed the noise immediately. Let me know if you want to know this part that we used. It worked perfectly and its very easy to install, just plug it in...very simple.
Old Apr 25, 2005
let the devil out
they could have put in no telling what but they could have damaged them or be defective ones at the same time. Make them check it or replace them since they installed it
Old Apr 25, 2005
coop's Avatar
I've never used Kenwood amps, so I don't know how well they filter noise, however my alternator whine disappeared when I installed an Alpine amp last Spring. I've got monster RCA's to my boston pro comps as well.
Old Apr 25, 2005
coop's Avatar
I used Radio shack ground loop isolators as civicstud mentions - it's a cheap fix and easily installed.
Old Apr 25, 2005
yeah...alright i'll try that if they don't fix the prob. where you get it? and how much??
Old Apr 25, 2005
^^^^ Yea that sounds about right, thanx Coop
jdawgzcivic
17
Feb 1, 2020 04:16 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
