subwoofer impedence
Old Apr 21, 2005
jack123's Avatar
jack123 is an unknown quantity at this point
subwoofer impedence
I have an mtx mono class d amp that says it can handle:
RMS Power measured at 12.5 Volts DC:
125 Watts x 1 into a 4 Ohm load with less than 1% Thd+N
250 Watts x 1 into a 2 Ohm load with less than 1% Thd+N
Now I have a subwoofer box with 2 10" subwoofers in it (some cheap *** subs that I have sitting around). It also looks like there are tweeters or something on the box. I don't know what brand they are or anything, I just know they are two 10" subs. I would like to test them out on my mtx amp, but am not sure if they will ruin the amp. How can i check if the impedence(ohms) are ok for my amp if I can't find the specifications for the subwoofers?
Old Apr 21, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
I'd almost guarantee that both those speakers are 4 ohms each. Wire it in parallel and you get an overall load of 2 ohms. Perfect to get max power out of the amp.
If you really want to check, get an ohm meter and test the coil of each speaker. It should be about 4 ohms.
Old Apr 21, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You need to have some sort of idea what the woofers are. Look everywhere for brand name, model numbers etc is the easiest way.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
wingsfan19
15
Sep 2, 2015 02:15 AM
LudlamTheory
Jul 28, 2002 03:45 AM
