headunit wont turn off!!!
Old Apr 19, 2005
M3RKR33's Avatar
M3RKR33 is an unknown quantity at this point
ok so check this.
i installed a 4 channel amp to power all my speakers, and im gettin alternator whine. so i had my key inside the ignition on OFF (so the car and my headunit were both off), while i was workin around the rca's. next thing i know, my headunit goes ON, with the car still not running!!??
i dunno wtf happened. and now, my head unit never goes off, even if i remove my key from the ignition. it only goes off when i remove the headunit's faceplate. wtf is goin on?? pls help!
i got an civic '02 coupe
headunit is a pioneer 7600mp
thx!
Old Apr 19, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
talk to justplainbad hes pretty good with all that stuff he helped me out when i had problems with my amp not turning off when i turned the radio off
Old Apr 19, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Check all of your connections. Sounds like you may have a short.
Old Apr 19, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
check behind your deck if the red wire going into your deck has power when your key is not in the ignition, if it does, you have a short somewhere in your car.
Old Apr 19, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
on a side note, i think that's pretty cool..heh
i'd like to be able to have music even without the key in the ignition...
solution => wire the deck's ignition wire to the battery and use the deck's on/off switch or remove the faceplate to turn deck off..lol...
Old Apr 19, 2005
MegaHurtz's Avatar
^^ you don't know how to make that happen?
Old Apr 20, 2005
M3RKR33's Avatar
no man this aint cool! or at least i dont find it so
05reverb, im not so experienced with this and wanna learn, so where would that short be? where should i look for it i mean. well first of all, by short u do mean 2 wires touching eachother when they really shouldnt right?
thx for ur help, guys
Old Apr 20, 2005
05reverb's Avatar
first, check that red wire going into your deck with your key not in the ignition. use a tester or a 12volt light, touch one end of the tester or light to somewhere that grounds to the frrame, and then touch the red wire to the other end of the tester or light. if the tester reads 12volts or the light lights up, you have a short or something wrong somewhere. then to find out more where the problem is, we would need to get more information on what exactly you were doing when it happened. where were you working on the RCA's (on the back of your deck or on the back of your amp)?
Old Apr 20, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
this is a power wire problem to the deck it shouldnt have a single thing to do with the amp or the speakers
Old Apr 20, 2005
05reverb's Avatar
I know that, but i just wanted to know if he was near the back of the deck when it happened, if so, he might have shorted the constant memory wire with the red ignition wire when he was working with the RCA's.
Old Apr 20, 2005
turboslug's Avatar
Super Hoser
i know how to make it happen but just never thought of the idea before..heheh
Old Apr 20, 2005
M3RKR33's Avatar
well i was workin with the rca's behind my HU when it happened.
and guess what. i just went behind there again, and checked around all the connections on the HU's adapter. they seemed fine.
so i tried out the "keyless powered HU prob" again and it still continued.
went out for a lil ride. and when i stopped, took the key out, it came back to normal!... damn random sob of a HU.. heh ok i guess its a bad connection somewhere tho...?
thx reverb for ur help!
AzNmiKex215
Jan 18, 2002 10:16 PM
my2k1vic
Jan 8, 2002 08:31 PM
LJ
Dec 10, 2001 10:48 AM
Foom
Dec 6, 2001 01:11 PM
