I'm in the market for a new deck and could use a bit of advice.
Originally Posted by kickercivic1
I wouldn't get alpine the preout volts is only 2.. Dont even think about panasonic. Mp3 plays,but takes time and its wont read cd if you even have small scratch. Your best Option is Pioneer DEH-P7700MP because they have 4v preout and cheaper then alpine plus more option and way way way better then panasonic.
BTW, I wonder if you have read the manual carefully. I downloaded the manual for Pioneer, it says "Preout max output level: 2.2V/1kW" (W=ohm), and RMS output 22W from 50-15000Hz(it doesn't play up to 20,000Hz at least!?) with 5% THD...I do believe it is a very poor unit
^^Well isn't that some ****. WTF. They put 4v on the spec page and 2.2 in the manual? And it only goes from 50-15k? It says that the CD response is 5-20k. Can it play cds at 20k if the channels only go to 15?
Son of a bitch! Now I'm right back to where I started. I only want to spend around $320 with components and shipping included. All the good decks are at least $300. I need to hear it.
If I were to go Alpine, it would probably be the 9853, but didn't you say that it doesn't have any kind of EQ? What about that Kenwood in the first post? I was just realy looking forward to getting some components too.
Going from 50-15k means that you virtually get quality like FM radio, so it still has a lot of details, but it means you are losing SPACE(it's among definitions of sound stage) and sub bass. Eventually no cd player can exceed 5-20k range while amp can. Everything beyond 20 and 20k make you feel the presense of a stage. Actually you don't "hear" much above 16k, but you will feel it.
I do suggest you go another route instead of HU->speaker->amp(normal and usual route, but also has the danger of double spending on same unit) because of your budget limits. Stock woofers are paper cones so it does give you some very natural midrange and you can use it for a while. By then you can save enough money to upgrade other things. My suggestion is to add a subwoofer first, because stock speakers just have no low end. It will fall well into your $320 range with a 2 channel amp, output at around 250W, and IDQ sub. Believe or not you basically don't need rear speakers, so get an amp with speaker level input. MRV-T320(small amp, 250W) bridged can push a dual 2 ohm 10" IDQ pretty well. I see one now on ebay says $99+15 shipping.
It's always my suggestion to get low freq driver first if you have limited buget because it will complete your frequency domain first. Believe or not, later when you upgrade, you can use that sub amp to push the main speakers. Sound nice to me, but just wonder if you will try this route.
Already have that covered with a 12" Kicker Comp in a sealed box and a Soundstream 600x4. I just need to replace this shitty JVC HU and possibly get some nice sounding components up front. I could live without the components for now, but I just don't see myself being able to save much in the future. Thats why I wanted to get everything now and forget about it for a while.
Well I had 2 in a bandpass and it sounded pretty good, but I decided to take one out and put it in a sealed box I made just for it. Now it sounds great.
I may not have posted that I had a sub.
My 2 cents:
I love my Pioneer (7600MP). I had a 6400 that I gave to a friend after 2 years of trouble-free use. If I had to list a gripe, it would be that the EQ is a little complicated to set, but I haven't really taken the time to sit down with the instruction manual and dial it in properly. That could be my Saturday project, instead of mowing the lawn!
The (optional) steering wheel remote is nice, too...
^^Thank you. I too had a Pioneer that I put in my first car 7 years ago, transplanted to my second car, and sold it to a friend a few years later. It still works, most of the time. It sounded pretty good to me, but I didn't know much about SQ back then. I want the Pioneer to be better, or the Alpine to be cheaper. Or to wake up and find out $100 bills fell out of my *** in my sleep.
Electric Boogaloo...
Originally Posted by 82801BA
Pioneer DEX-P9 plus DEQ-P9 and the upcoming Alpine F#1 DVI-9990 couple with PXI-H990, for which the P9 combo is far less expensive than F#1 combo. Looking for retail $2500 and $7000, respectively. I know nobody in this forum will actually looking into those, right?
I believe F#1 comes in as a complete set, retailed well over $20,000. The new line consists of DVI-9990, PXI-H900, SPX-Z18T 3-way pair, SPX-Z15M center, SPX-Z15M x2 rear, and at least 3 MRV-F900 to complete the whole system(without video). While the SPX-Zxx speakers are actually Scan Speak Revelators, exact same drivers for ring radiator($450 each), and 4" and 7" cone(4 ohm version, around $200 each at Madisound), and 5" cone($200 each). Retail price of SPX-Z18T is $3500 while SPX-Z15M is $1500. MRV-F900 costs $3500 each, 2 of them are recommended by Alpine to run an active 3-way front system(one for tweeter and woofer, one bridged from 4 to 2 channel to push the 4" midrange). No price has set up for DVI-9990 and PHI-H990 yet. But each of them will not be less than $2500. Alpine has started to get away with Ai-Net to incorporate IONBus and IEEE1394 link for connections, which will offer true digital, or at least higher bandwidth analog between components(that's where the I comes from).
Nah, you can get the pioneers for 749.99 for the actual HU, and 549 for the processor. Woofersetc, for one has it. Awesome, awesome unit...
Good points. Alpine is targeted at car audio and they do have a better product, but this is where price comes in. I can get the 9853 for 260 which leaves me with 60 measly bucks for components. Not gonna do a whole lot with $60. The 9855 is available for around $400. Way more than I want to spend.
I like a full, natural sounding system that covers the entire audible spectrum and makes the music feel real. I also want to get as much as I can with my money. I'm going to do some scouting tonight and try to see and hear the Alpines and Pioneer and Kenwood HUs. Thank you for your continued advice.
^^Awesome! I'll PM you for the details. You'll also be happy to hear that I went to my local Tweeter tonight and they had both the 9853 and the P770MP. I'm getting the 9853. It really is a far superior unit to the Premier. The Rotary Commander felt cheap and weak. I'm not sure if it would last too long. It also felt like it took too much effort to command the roraty. Maybe it felt that way because it was a display model?
The Alpine was amazing. Sounded great with every speaker in that room. It has 6 position time correction and a 7 or 5 band EQ. I think it will definately be worth the little extra. I can't wait to get it.
Thanks to everyone who gave their 2 (or more) cents. I really appreciate it!
The truth is that, time correction works best with active crossover rather than passive(or at least bi-wired on the crossover if supported). The reason is that, you delay one speaker, the whole set will be delayed if you are using passive, will doesn't work well this way. With active, ie. tweeter and woofer receives its own channel, even just using internal power of the head unit, you still will be able to adjust every driver to the exact value. Then they can be matched and blended seamlessly(that's what I am doing with the Dyns now).
just wanted to chime in. I am basically in the same boat... i'm looking at either the DEH 770mp (because of AAC compatibility and price) or comparing the 9853 and the p8mp.
i know alpine has a huge following but i hear people arn't liking this glide touch thing. Does anyone have it? I prefer the rotary commander on the pioneers... i also want to hook the IPod up so i was wondering if anyone has tried the new pioneer interface.
thanks
thanks
thanks
thanks
(Only IF the new unit is made in Japan, not China)And, by the time I buy the new one, I will sell my older DVA-7996 for the price below $300, which has digital output also.
BTW, anybody notice that Alpine dropped V-Drive internal amp?
probably because those decks are so expensive that you can just buy a non v-drive and an external amp for just as much money
...or maybe alpine is planning something better...
maybe they're thinking of using one of those tripath ic's for even more power than the 26watt v-drive ones
carid
Aug 8, 2015 05:05 PM
