Where does the power antenna wire go???
Old Apr 15, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
Where does the power antenna wire go??? I am still having that prob with my amp, sub and radio combination. Where my radio signal fads when my amp is on (Jl 500/1 with signal sensing feature) (Jlw3V2-d2) (Pionner 8400mp) PLease help !!!
http://www.7thgencivic.com/forums/sh...d.php?t=204732
Old Apr 15, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
how is wired up?
Old Apr 15, 2005
SlimmKidd's Avatar
Power wire and from the wiring harness to the wiring harness onthe deck...........
Old Apr 15, 2005
Kyle23's Avatar
u dont make sense
Old Apr 15, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
our car doesnt need the power antenna wire..
Old Apr 15, 2005
Kyle23's Avatar
oh! ur hooking up the stock wiring harness to the aftermarket one? that makes sense. Just cap it off u dont need it
Old Apr 15, 2005
dma001's Avatar
dma001 is an unknown quantity at this point
Are you sure your antenna wire (the fat black one with the silver plug) is securely plugged in?
I don't quite understand the "power antenna wire" discussion; I never did any splicing, and my radio reception has been fine from day one.
Old Apr 15, 2005
SlimmKidd's Avatar
my radio works fine its just I cannot get certain stations unless I am closer to the actual station.
Old Apr 17, 2005
TeLLy's Avatar
Yes, it's an Acura EL
http://www.7thgencivic.com/forums/sh...d.php?t=197037
http://www.7thgencivic.com/forums/sh...d.php?t=181951
http://www.7thgencivic.com/forums/sh...57&postcount=6
Old Apr 17, 2005
MegaHurtz's Avatar
some harnesses do not have the power antenna wire on them. i have used 2 harnesses now on my car, the first did not have a wire to hook up the powerED antenna, the second did.
Note the emphasized ED. From my understanding, our car has a powered antenna (different from power) and you have to have the harness with the powered antenna wire to get the best reception.
Old Apr 17, 2005
SlimmKidd's Avatar
but where does it get hooked up to???? I already screwed my radio to day trying to fix this problem I spliced into the Cigarette lighter cause someone said it (power antenna need power) so I did that and I think the loose wires with no tape on it touched something bad but my radio fuse isnt blown
Old Apr 17, 2005
MegaHurtz's Avatar
heh
the power antenna wire on your aftermarket harness gets hooked to the blue or blue/white wire on your deck
Old Apr 19, 2005
Pluto's Avatar
Pluto is an unknown quantity at this point
wow, i've had an aftermarket JVC deck for 2+ years in my car without ever having the power antenna wire hooked up (no wire on my harness) - my FM reception was always pretty good and I could use the mono mode on the deck to pick up distant stations clearer.
My new Kenwood deck has noticeably worse FM and no mono mode so I am definitely gonna be pulling it out and hooking up that wire asap.
Old May 22, 2005
Pluto's Avatar
arghh, I just got around to taking my deck out to check out this power antenna wire issue....
The Green/Yellow wire on the honda side lines up with a gray wire on the aftermarket harness side (one of the speaker connections)
My harness does in fact have a power antenna wire but it doesn't line up to any wire on the honda side of the plug...
The only wire not being used from the honda side is the 'dimmer' wire since my deck doesn't have this function.
Is it possible only certain models / years have this hookup? Mine is an '02 Sedan
Help!!!
Old May 22, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
We visit this every month.
The power antenna lead from your deck goes to the green/yellow factory wire.
Old May 22, 2005
Pluto's Avatar
Well my car must be special then because unless I'm totally retarded that wire goes to a speaker wire. I would take pics but my camera is out on loan atm.
Old May 22, 2005
Pluto's Avatar
OK here is what my harnesses look like:
Honda side:
X 2 X X 5 6 7 8 9 A
X X X X F G H I J K
2 = Yellow/Red
5 = Pink
6 = Blue/White
7 = Yellow/Green
8 = Green/Black
9 = Red/Black
A = White/Red
F = Yellow/Black
G = Blue/Black
H = Grey/Red
I = Green
J = Red
K = Black
Harness side:
1 2 X X 5 6 7 8 9 A
X X X X F G H I J K
1 = P.Ant/Blue
2 = 12V Red
5 = Right Rear+ (Purple)
6 = Left Rear + (Green)
7 = Right Front + (Grey)
8 = Left Front + (White)
9 = Illumination / Orange
A = 12V memory / Yellow
F = Right Rear - (Purple/Black)
G = Left Rear - (Green/Black)
H = Right Front - (Grey/Black)
I = Left Front - (White/Black)
J = Dimmer (Orange/Black)
K = Ground? (Black)
As you can see pin 7 which is the wire referred to as the antenna wire goes to the Right Front positive speaker wire on my harness. Pin 1 on my harness does not have any wire that corresponds to it on the honda harness side.
I'm starting to think my car just doesn't have the powered antenna...
Old May 23, 2005
mrhahakoala's Avatar
mrhahakoala is an unknown quantity at this point
does this powered antenna wire coorespond to the remote turn on wire for an amp?
Old May 23, 2005
SlimmKidd's Avatar
What have I started????? I thought this was dead!!!!!! I still havent fixed my problem but I have since given up might post some pics later............
Old Jul 30, 2005
TriumphS3's Avatar
TriumphS3 is an unknown quantity at this point
Sweet that fixed my problem. My harness did not have a yellow/green connection. My deck had a Blue/White for power antenna, so I spliced the yellow/green and hooked it up to the Blue/White. Now, the am AM radio works and the FM station reception seems stronger.
Old Sep 11, 2013
hyper_cool's Avatar
hyper_cool is an unknown quantity at this point
Re: Where does the power antenna wire go???
Help!!!
Hi there Buddy,
I'm kind of having the same issue as you. I'm just wondering if you got this issue resolved and what did you do. I do get FM reception but sometimes cuts out or gets really weak the fact that I live in the city. I noticed my aftermarket harness do have a blue wire for auto antenna/power antenna but there's no feed coming from my Honda wires. I do have a sedan like you. From what I heard the power antenna line is only available for coupes? Is this true. Thanks man.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
cdt12271
Apr 23, 2015 11:36 AM
darwin-t
Apr 18, 2015 09:29 PM
Dmitri
123
Oct 13, 2005 08:01 PM
