JL 300/4 more like 225/3 : (
Old Apr 12, 2005
gatorsactions's Avatar
gatorsactions is an unknown quantity at this point
Exclamation JL 300/4 more like 225/3 : (
Well my bro and I finished the stereo install this past weekend. I think we worked for about 30 hours. I guess that's what happens with a couple of newbies... anyway, it seems as though we only have 3 out of the four channels working on the amp. We did a quick test and swapped the wires to be sure it wasn't the speaker or wire. Is there a way I can text at the amp output to see if that channel is putting out power?
Maybe I shouldn't have bought the amp from some dude on eBay...
Old Apr 12, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Do you own a DMM?
Old Apr 12, 2005
MegaHurtz's Avatar
sine wave and multimeter set to acv at the speaker outputs
Old Apr 12, 2005
MegaHurtz's Avatar
failing that, get a speaker and a short length of wire and just test it from the trunk
Old Apr 12, 2005
MegaHurtz's Avatar
dont blame the wire... i've never seen wire failure unless it was at the connection point which isn't really the wires fault
Old Apr 12, 2005
eye_see_you's Avatar
let the devil out
useing a DMM at the speaker outputs or a short wire and speaker at the amp is always the best solution.
* oh yea JL has no online resellers and no warranty for anything purchased from the web or persons so if it is messed up good luck *
Old Apr 12, 2005
MegaHurtz's Avatar
well you can always pay out of pocket to get it repaired
-or-
slap it back on ebay
Old Apr 13, 2005
Originally Posted by PopcornPlaya
Do you own a DMM?
What is a DMM? I don't think I own one....
Old Apr 13, 2005
If there is a problem with the amp, what should I expect to pay to have it repaired and where would I take it?
Old Apr 13, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Call a local car audio shop and ask for amp repair shops, or how much they would charge to send it out. Expect to pay anywhere from $100-$250 depending on the issue.
This is reason #1 why I always buy authorized
Old Apr 13, 2005
maybe I'll have to resell on eBay and get a replacement amp : ) Of course I will be honest enough to state the problem with the amp
Old Apr 13, 2005
burke420's Avatar
The World Is Yours!
JL AUDIO will let you send back their amps in some cases and let them fix it so that you can have it working, again. it may cost some change to do so, just hope that your serial # is still on the amp or JL wont work on it ir you want to gget it fixed, but NEVER buy JL products online due to their online policy of being able to work on malfunctioning electronics, when u actually get them!
Old Apr 13, 2005
MegaHurtz's Avatar
upon reading this thread again it seems to me that a single channel on an amp as good as a JL would fail... play around with it for a few hours and see what you can come up with...
change your rca connections, check your rca's at the deck, change all your speaker connections, do a test with a short length of wire and a speaker... basically exhaust all other possibilities before sending the amp in
280zforce
Dec 8, 2010 11:10 AM
ExstInt
Sep 13, 2010 10:47 AM
316
Mar 8, 2009 06:47 AM
iaerosolart
Jan 1, 2007 09:00 PM
Zeppelin8778
Dec 8, 2005 06:15 PM
