quick electrical question
Old Apr 4, 2005
NoiSe's Avatar
I'll be installing a capacitor, and I need a reminder on a few things..
First, remove ground wire from the amp, then remove power wire from the battery. Connect power wire to + terminal of cap., then run a power wire from + of cap to + of the amp. Then, reconnect power wire back to battery, and finally ground both amp and capacitor.
Am I thinking correct here?
Old Apr 4, 2005
MegaHurtz's Avatar
thatll do it
Old Apr 4, 2005
NoiSe's Avatar
so the sequence is correct?
Old Apr 4, 2005
MegaHurtz's Avatar
yep youll be fine
Old Apr 4, 2005
MegaHurtz's Avatar
mnight want to charge your cap though
Old Apr 5, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Caps charge instantly.
Old Apr 5, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Yeah you could do the classic "quick charge"
Old Apr 5, 2005
What the hell are ya'll talking about charging a cap? They charge instantly, the second you hook voltage up to them they're charged. There's no slow or quick charging procedures.
Old Apr 5, 2005
Ed's Avatar
Ed
You should charge the cap first using a lamp or a resistor, or damage can occur to the capacitor.
Old Apr 5, 2005
NoiSe's Avatar
yeah, I still have to do that.. I just wanted to make sure that I disconnect everything right
thanks all
Old Apr 5, 2005
BucketHead's Avatar
BucketHead is an unknown quantity at this point
Be CAREFUL!
...Sorry for not reading through the whole thread on what you are doing, but I did notice you are going to "pre-charge" a capacitor before installing it...a good way to get zapped if you ask me. Of course, the size of the capacitor will determine your reaction to it and that in turn will determine just how hard you hit your head on the raised hood!
Seriously...I'd recommend installation without precharging...
Old Apr 5, 2005
NoiSe's Avatar
wouldn't that kill my battery though?
by the way, this is a used capacitor, I got it off someone I know.. so it has some charge left in it (I checked), it's just been sitting in my basement for the last 3 months
Old Apr 5, 2005
BucketHead's Avatar
Pre-charge or not...
I presume you are installing this for your sound/video gear? It SHOULDN'T be a problem for your battery...are you installing this on a switched circuit? Any relays or anything to control it?...If it is on a switched circuit, just have your car running when you hit the switch for the first time...
Old Apr 5, 2005
MegaHurtz's Avatar
i never charged mine but some caps do come with charging circuits thats why i suggested it, but I also think its pointless
Old Apr 5, 2005
NoiSe's Avatar
I'm sorry, I don't know what a switched circuit is... I'm not very good with electrical, that's why I asked.
I don't have a relay, it's a very basic audio system. I just have 1 amp, and 2 subs running off it.
Old Apr 5, 2005
MegaHurtz's Avatar
don't overthink the process man, it's super easy to do, hook it up and away you go
Old Apr 5, 2005
BucketHead's Avatar
MegaHurtz is right...just do it...
...it sounds like it will be controlled using your amp's power - a switched circuit; turn the amp on/off controlling power through the cap...
A straight forward set up and not too elaborate -- sometimes the best way to go!
Enjoy,
BR549
Jun 25, 2015 04:03 PM
thana
Jun 15, 2015 11:58 PM
manicEL
Dec 10, 2001 06:33 PM
viper775
Dec 9, 2001 10:52 PM
MooCoW
Nov 9, 2001 05:22 PM
