what size amp?
Old Apr 4, 2005
hookitup34's Avatar
hookitup34 is an unknown quantity at this point
what size amp?
i just got a new 12" jl w1 the silver one and dont know what size amp would be best for it. also if you could recomend some brands that are good. thanks for the help. specs are listed below from the jl web site.
12W1v2 12-INCH SUBWOOFER
Continuous Power Handling (Pt):
150 Watts
Nominal Impedance (Znom):
Single 4 ohm or single 8 ohm
One-Way, Linear Excursion (Xmax)*:
0.375 inches / 9.5 mm
Nominal Diameter:
12.0 inches / 300 mm
Overall Diameter:
12.5 inches / 317.5 mm
Mounting Depth:
5.09 inches / 130 mm
Net Weight:
8.61 lbs. / 3.90 Kg
Driver Displacement:
0.035 cu. ft. net / 0.99 liters
Rec. Sealed Enclosure:
1.25 cu. ft. net / 35.4 liters
Rec. Ported Enclosure:
1.75 cu. ft. net / 49.5 liters, tune to 28 Hz
Old Apr 4, 2005
tripledoublegs's Avatar
Euro-Spec
those subs only take up to 150w rms, so almost any amp should be plenty to push it. Just make sure you don't overpower them.
Here's one amp that you can run at 4 ohms and should do just fine. Don't turn the gain all the way up though :alpine amp
Old Apr 5, 2005
hookitup34's Avatar
thanks for the help
Old Apr 5, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Well, It's ok to overpower it a little if you want and keep gains low low. Personally, I'd say go for the JL E1200. BTW -that's a sexy Sub - good call, I'm dying to know how it sounds, keep me posted.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
68camerors
Sep 24, 2015 06:18 PM
