Bass blockers form Crutchfield
Old Apr 4, 2005
rloyola0426's Avatar
rloyola0426 is an unknown quantity at this point
I was thinking about getting these bass blockers from Crutchfield but I wanted to know your guys opinion on them first. They aren't that expensive but i'd hate to buy something that is useless and just a piece of junk. So let me know if you think or know that they do or do not work. I myself am going to call Crutchfield to ask for their opinion as well.
I wanted to get them because my speakers are running off my clarion head unit and they distort when I have the volume too high. I am running a JL 12" sub so I'm not worried about losing bass from my smaller speakers. In fact, I'd rather they just focus on mids and highs, rather than trying unsuccessfully to create bass.
Here's the link:
Crutchfield bass blockers
Thanks everyone in advance
Old Apr 4, 2005
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
what's your current setup? Are you using the stock speakers?
Old Apr 4, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Are you running components, coaxials, triaxials, stocks, amped or not?
Old Apr 4, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
You might be able to use simple resistors with the correct value.
I have not heard any negative about the Bass Blockers. Crutchfield does have the money back guarantee also.
Old Apr 4, 2005
I have a 2001 Civic coupe EX.
In the front I am using Pioneer 4-way 6 1/2" speakers, along with the stock tweeters in the door. The rear speakers are the stock 6x9's that came with the car. They are all hooked up to my head unit, which is a Clarion proaudio. The JL sub runs off an amp that has its own crossover so I'm not worried about that. But the front and rear speakers both run off the head unit, which does not put out much RMS, probably just 14 - 18 watts RMS since max is supposedly 50 watts. They are not getting too much power, so they do not produce much bass. I wanted them to be dedicated to just producing mids and highs, which they do perfectly. Any advice?
Old Apr 4, 2005
simple resisitors will do fine
Old Apr 4, 2005
The bass blockers are probably your cheapest option, and if you have the amp on the non-fading output, you might try adjusting the bass down a bit on it, and then turning your gain up on the amp ever so slightly. If you had them on an amp you could turn them the frequencies and cut off the lower frequencies, but with them off the deck the bass blockers wiill probably the cheapest solution though.
Old Apr 4, 2005
Are resistors cheaper than the Cruthcfield bass blockers? And if so, how do they work? How would I choose them and then how would I connect them? Any and all info would be greatly appreciated. Thanks.
Old Apr 4, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
use the green ones. they still give u a little mid bass but not much. also dont turn up the bass on ur radio.
Old Apr 4, 2005
gizcivic's Avatar
gizcivic is an unknown quantity at this point
the way i did it is i turn my bass down and just turn up the non fade
Old Apr 4, 2005
Resistors are ALOT cheaper.
You wire them inline on the positive lead to the speaker.
What size depends on the frequency you want to crossover at, the speaker ohm load, and possibly what slope of crossover.
Old Apr 4, 2005
Ed's Avatar
Ed
I don't think any type of resistor will do what you're looking to do. I'd definitely look at your HU's manual, a lot of HUs have LPFs built in that you can adjust, maybe you can jsut turn it on?
If anything, you'll want a capacitor over a resistor.
Actually, after looking at crutchfield, all those bass blockers are are capacitors I'l assume your speakers are 4 ohms:
120hz:331 uf
100hz: 400 uf
80hz: 500uf
If you want it for another frequency, search for an online crossover calculator.
you can get them at parts express for a couple bucks a piece. If you need a lower crossover frequency, you'll need
http://www.partsexpress.com/webpage....ctGroup_ID=161
Old Apr 4, 2005
zachgeyer's Avatar
hum sould i do this aftermarkit deck stock speackers
Old Apr 5, 2005
Ed's Avatar
Ed
Hrm, sentence?
Old Apr 5, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
Even if you turn off all the bass going to them and use resistors and such, you will always have distortion at a certain level.
Best bet, get a 4 channel amp, does not have to be anything fancy, but here is one that is.
http://www.bestbuy.com/site/olspage....=1099388650775
That would take care of your problem, not only giving your speakers sufficient amount of power but allowing you to set the crossovers.
Rlss
24
Feb 26, 2016 09:42 PM
Juanb24
Sep 15, 2015 12:39 AM
Deeup511
Aug 30, 2015 04:48 AM
carid
Aug 14, 2015 05:46 AM
wishihadavtec
Feb 3, 2002 09:17 PM
