Subs still goin when i turn the radio off
Old Mar 30, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
When i hit hte **** on the radio to turn it off not turn down the volume but actually turn off the radio the subs stay on and have a low humming noise what is there to fix it
i still have the factory head unit
Old Mar 30, 2005
justplainbad's Avatar
Victory is Mine!
justplainbad is on a distinguished road
My guess is you tapped into the wrong wire for the AMPs remote turn on. Maybe an ignition wire, you should tap into the Amp out or Power Antenna wire (AMp out if using an aftermarket stereo, powered antenna if using the stock stereo) this will turn the amp off when the stereo is turned off.
Any questions, feel free to im or pm me.
-Nick
Old Mar 30, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Tap your remote wire (that's the blue one that goes to your amp from teh HU, or elsewhere) and tap it into a switched source. There's a blue one in the wiring harness on an aftermarket unit, but if you're going stock you'll want to tap into something such as the accessory wire in the car's switch, or into the positive wire on the accessory plug/cig lighter.
Old Mar 30, 2005
Victory is Mine!
Well, if he taps it into the accessory wire, the amp will still be on when he turns off the radio, he wants to tap it into the yellow/green powered antenna wire from the back of the stock hu.
He has the stock hu.
Old Mar 30, 2005
The ACC wire. The one for when you have the key turned to the ACC position. It only gets power when the switch is in the ACC position or is turned on/running. Also, if it were me, I'd tap into the cig lighter as it's the easiest to get to, especially if everything has already been put back in. You only have to pop that one panel off and bam, there you go, wire in an easy place.
Old Mar 30, 2005
But he doesn't want it to stay on all the time! Tap the power antenna wire.
Old Mar 30, 2005
You know, I feel dumb now that I read this... I was thinking he was having an issue with it killing the battery when the car was off... That's what I get for multitasking and reading 4 threads on 3 boards at once... Yes, the power antenna wire. If you don't know which one, get out your DMM and find it.
Old Mar 30, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
i thought the remote amp turn on wire is always blue?
Old Mar 30, 2005
skipbarber's Avatar
An amp can be on and not make noise, so i doubt it's the remote turn on. It sounds like a bad ground to me. Is it an MTX or Sony amp? those are notorious for doing that when poorly grounded.
Old Mar 31, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Also if he uses the power antenna wire I believe the amp will shut off when he switches to CD mode.
Old Mar 31, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
buy a fuse jumper and run a wire from your cig lighter fuse, works great on mine
Old Mar 31, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
sounds to me like they're getting the wrong voltage to them...
Old Mar 31, 2005
Victory is Mine!
In most cases your right, but the ones in our car, Civics, stay on. At least in the 02 EX they did, and I dont imagine they changed anything.
Its good for us, and probably just less circuitry Alpine had to use when Alpine made our decks. You can also throw that wire into a relay and up the power to it if you dont think its enough.
Old Mar 31, 2005
the amp is a crossfire vr602 amp
Old Apr 2, 2005
problem is fixed
Old Apr 2, 2005
Ed's Avatar
Ed
How'd you fix it?
Old Apr 3, 2005
Originally Posted by Ed
How'd you fix it?
i listened to justplainbad
and he knew what he was talking about so i followed his instructions he sent me and it worked
Old Apr 3, 2005
Victory is Mine!
Anytime, I installed professionally for years, happy to help!
-Nick
trellex
May 24, 2015 04:39 PM
ayoitzjulesdx98
May 13, 2015 08:31 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
