What kind of speaker wire/RCAs?
Old Mar 30, 2005
2k2civic's Avatar
Anyone have any recommendations on what brand/type/size of speaker wire I should use for my components? I am currently using crappy 16 gauge wire and getting some noise (I know it's the wiring cause I used to have the same RCAs, ground, but different speaker wire with no noise. I would go back to the Monster cable but I wanted to know if the knukonceptz twisted wires would work better for my situation (I'm running two pairs of wires up each side and would like to do it with either one cable or flat cables). Anyone with any experience or advise, please let me know. I'm also planning on replacing my RCAs and looking for recommendations.
Old Mar 30, 2005
BigGeorge's Avatar
BigGeorge is an unknown quantity at this point
I have the lightning audio 4 gauge kit. My rca's are the fosgate with the remote wire attached to them....nice
Old Mar 30, 2005
MegaHurtz's Avatar
knukonceptz is great stuff for cheap-ish
wire is wire generally though, as far as speaker wire anyway, just get the appropriate size
that being said, I run 14awg from my trunk to my front speakers, was going to run 12 but ordered some off ebay and it wasnt here yet so I said *** it and went with 14awg that I already had
I run 12 from my xovers under the dash into the doors, and 12 from my sub amp to my box as well
As for RCA's, I run some uber expensive Stinger Expert Series. The ends screw off so that you can push them on, then screw the end back on so it clamps down super tight for an awesome connection. Aside from that, they are thick as ****.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
