system wiring question
Old Mar 28, 2005
satinsilvervic's Avatar
satinsilvervic will become famous soon enough
I just bought 2 audiobahn 10" subs AW1051T http://www.audiobahninc.com/frame2004.html
and i had a autotek amp XS-400.2 http://www.carreview.com/Amplifiers/...3_1806crx.aspx
I did't realize the other subs i was using were not dual voice coils... So my question is will this work and can you give any info on how to wire these. thanks
Old Mar 28, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Heres JL audio's website that teaches you the different ways you can wire your subs.. hope this helps!
http://www.jlaudio.com/tutorials/wiring/index.html
Old Mar 28, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
wire both subs in parallel, each sub will then be 1ohm then series what you have left over one pos to one neg, then you will end up with one pos and one neg to run to the amp bridged like so:
Old Mar 28, 2005
but there are 8 connections on the sub 4 positive and 4 negitive
Old Mar 28, 2005
ex_03's Avatar
Godlike member
pick no work(red X)...make work!!
what are the specs on the sub then, Becuase I must be looking at the wrong sub!
But is it 4 - 4ohm voicecoils? cuase if it is, then the same applies, Wire all coils on one sub in parallel, then do the same on the other, that leaves you with two wires coming off the sub- one pos and one neg.Follow?
Old Mar 28, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
http://www.audiobahninc.com/tech/wir...ug_wiring.html
Pick a way you want to wire it and it will show u a picture, not to say yours wasn't a wonderful work of art ex_03,this is just a tad more pretty.
Old Mar 28, 2005
Rennen's Avatar
New Mod on the Block
is there an advantage when wiring it one way or the other???
Old Mar 28, 2005
ok i got i idea of how to wire it thanks ChaoticMav and ex_03.... but one last question the positive and negitive that connect the two speakers can i connect them to the positive and negitive that go to the amp so i can run the wires out the back of the box... because there is only 1 + and 1 - on the box and i need three wires to come out of each side of the box
Old Mar 28, 2005
ex_03's Avatar
Godlike member
no it just gives you more options when picking out a system. And listen to someone come in here and say different. Resistence is resistence no matter how you look at it. What does matter is how much!.
Old Mar 28, 2005
ex_03's Avatar
Godlike member
I wouldn't, I would do it inside the box then to the terminals of the box.Do you mean outside of the box?
Old Mar 28, 2005
chaoticmav's Avatar
I imagine you mean the wires that go between the speakers you want to connect to the amp instead that way you don't have to drill a hole or bigger one?
If each speaker is sealed in it's own area *if I am reading right*, your gonna have to find a way to connect them, your best bet is to drill a hole JUST big enough to run those wires out the back of one speaker into the back of the other one, don't drill through the wall seperating them, drill through the back and run from one side to another, then make sure you seal around the wires with whatever you can that way the box is still *sealed*.
Old Mar 28, 2005
no i meam i have 1+ and 1- connecting the two subs and i have 1- amd 1+ going to the amp so on one side i have 2+ and 1- and on the other side 1+ and 2-. i need to know if i can connect the 2+ and the 2- together so i can run them to the terminals on the box on the inside. i hope you can unerstand what im trying to say because i really don't want to take it and get it done because im stumped
Old Mar 28, 2005
yes thats what im talking about thanks for all your help i guess im going to try to do that
Old Mar 28, 2005
ex_03's Avatar
Godlike member
yes you can do that:
sub 1. 2+ / 2- . 2 + to the terminal inside box and then 2- to the terminal inside box, on both subs. Then run a wire from + to - outside box then that leaves you with 1+ and 1- for the amp?
double check with dmm @ the amp, if you have one.
Old Mar 28, 2005
can you show me how you would wire it? the bottom left 2 and the top right 2 are positive
Old Mar 28, 2005
ex_03's Avatar
Godlike member
Ok dont get confused but this sub is only a dual voicecoil not four voicecoil, The extra screws are there just so you add wire but each set of 2 screws is for one terminal- 2 screws for pos. 2 screws for neg on each side of the sub.I actually bought some these at discount to sell for making some extra green, But yea if the my yellow line is wrong just ignore but you understand run one wire from pos on one side to neg of the other, that will leave you with a pos from one side and neg from the other thos are the wires that you run to the terminals inside the box. So when you run a wire from the pos of one connector on the outside of the box to the neg of the other connector, you will have a pos left over and neg left over to run to the amp!
Old Mar 28, 2005
ex_03's Avatar
Godlike member
that will run your @2ohm mono. Hoped this helped.
Old Mar 28, 2005
thanks for your help ill try that.
Old Mar 28, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
The extra terminals are so you don't have to splice depending on how you are wiring the voice coils. Both + and both - go to the same voice coil, so pick 1 and ignore the other, like so
(note the blue is simply a wire connecting the pos to neg.)
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 3, 2015 02:17 PM
