Is it possible to wire up our instrument panels like this??
Old Mar 27, 2005
Al Gore FTW's Avatar
jdmtytedoridori
In Saabs, there is a button you can push that says night panel. basically what it does is shut off all dash lighting and instrument panel lighting, except for tach and speedo. I was just wondering if it would be possible to do this in our vics.
Here's what it looks like in saabs:
Old Mar 27, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I know that buy following gearbox's diy for changing the color of led's you can. With mine I just added green led's for my needles and I left the white led's alone. With that in mind you can add what ever color led's you want, you would just have to run them in clusters of 3, like 1 cluster for rpm / one for speedometer/ and then gas. you would then control them by three dimmer switches.Also by that I mean you don't remove the small led's that are soldered to the curcuitboard you just cover them up, then add the new led's.
Old Mar 27, 2005
AlienX's Avatar
AlienX will become famous soon enough
that exactly what i was going to say Or if you want to keep your stock color then youc an just cut the connection to some bulbs and wire them up to a seperate power supply ( fused )
Old Mar 28, 2005
jdmtytedoridori
sweet, ill probably look into that when i get my new cluster
JUNITO
Jul 9, 2015 08:36 PM
aultman1990
Jul 9, 2015 08:27 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
