RCAs can make a difference?
Old Mar 22, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Ok, Either I've just proven myself wrong about something, or something is going on that I am not aware of. Putting an amp in my GF's car. So, naturally she needs RCAs. Well, Using my hookup at a local shop, I pull off 2 pairs of Micro XLNs for cough* $43.00 for both. Well, if I'm frontin' the dough, you had better believe I'm getting the XLNs and she's getting my old RCAs. So, today I ripped out my old 300 series Monster RCAs and put in the XLNs.
OMFG - I have no idea what the hell happened, but my bass is hitting much harder. Strange. Now, normally I am a big proponent of RCAs are RCAs, they make a very minor difference. This is not minor. I had to turn down my gains after this. First assumption would be the old cables are F'd up. But how could a faulty cable deliver a perfectly clean sound, just at a lower level? Anyone have any insight?
Old Mar 22, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
I always thought the difference wasn't worth the money?
Old Mar 22, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
RCA's make some difference if you are to run it in very long configuration because of noise intrusion and voltage drop(well, not really). Otherwise, it is the money and cosmetic issue. I was told by my friend at a car audio shop that you don't really hear a difference unless you have a gold ear.
I keep my RCA's as short as 3 ft and they are grouped at one place, so no difference.
Old Mar 22, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Are the new RCAs significantly shorter than the old ones?
Old Mar 22, 2005
82801BA's Avatar
No, because I am running external processors, everything's in the trunk. I don't have RCA running from head unit to the trunk. From HU I have fiber optics to the processor.
Old Mar 22, 2005
3 feet? So your amp is mounted where then?Only thing I heard was don't run rcas next to power wires and you'll be fine.
Old Mar 22, 2005
J187's Avatar
No they are the exact same size. Same exact install, I literally just cut the wire ties and put the new ones in.
Old Mar 22, 2005
82801BA's Avatar
Better connector means better conduction. For seriously, get any kind of cheapest shielded cable(unshield is fine for short distance) and change the connector will work out great. Just no reason to pay premium $99/15ft cable.
Old Mar 22, 2005
I just hooked the bare wire straight to the amp connections. I guess that's as good as you get.
Old Mar 22, 2005
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
J187, do I know you? I just had a good customer buy some XLN's a couple days ago? BTW, I've found (after doing several +$20,000 systems) when it comes to RCA's, cheaper is better, and do NOT buy twisted video cables! Just my .02.. We spin all our own RCA's to length, and never have a problem. Break out the pricey Monsters, noise. The uber-expensive JL cables, OTOH, no problems.
Old Mar 24, 2005
J187's Avatar
Not I that bought those XLNs, A friend hooked me up. Where do you work at?
Old Mar 24, 2005
joescivic02's Avatar
Abercrombie and Fitch
i have 50 dollar monsters from my stingers and noticed no difference
Old Mar 24, 2005
Bires's Avatar
Bires is an unknown quantity at this point
maybe your old RCAs were crimped from panels or one of the ends was damaged. I've used Scosche RCAs and Monster Cable RCAs, and they both sounded fine, when the install was done well.
Old Mar 24, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
i thought RCA's really make no audible difference? It probbaly might count if your trying to get every last Db out of your system. But for the avg joe i dont think it makes a difference.
Just dont go super cheap and get ones that are made of like string and cheese. haha
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jbander
Jun 4, 2015 05:56 PM
Youshoe
May 22, 2015 09:36 PM
bsmiley
Apr 27, 2015 01:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
