Question about Volts
Old Mar 21, 2005
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
When i drive down the rd it's at 14volts, then I turn up my system and it drops to 12 or a little lower, then goes right back to 14. Or when I turn on my Defroster, it goes to 12 or below a bit like 11.Or when I'm at a idle. I just got a new alternator. I ahve a 1000watt memphis amp.. Could that be drawing a lot of power?
Old Mar 21, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Naturally,every time you turn on an electrical device it's going to draw current, causeing you to get a lower readout. Are you measuring it at the battery (within 18 inches) or elsewhere?
Old Mar 21, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
Originally Posted by Marcus
I have a 1000watt memphis amp. Could that be drawing a lot of power?
Well technically, it will draw 1,000 watts because watts = power. But I assume you are referring to amps.
Amps = Watts/Volts
1000 watts at 12 volts gives 83 amp load.
So I would answer your question as yes, 83 amps is a hell of a load for a typical alternator.
FYI: 1,000 watts (1kW) is equal to 1.34 horsepower. But since the alternator is typically only 55-60% efficient, then it consumes 2.25 HP. But since the belt is only ~93% efficient then the engine is having to put out about 2.5 hp to power your amp when you have it set to "11".
Old Mar 21, 2005
Marcus's Avatar
Nope, I'm measuring it at the Headunit for power
Old Mar 21, 2005
Measure it at the battery and you should get a more steady reading. You're going to have some line loss at the HU.
Old Mar 21, 2005
Marcus's Avatar
ok I will try it out, thanks PopcornPlaya
Old Mar 21, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Also, measure it without the amp connected and you'll know how the amp is effecting your electrical system
Old Mar 21, 2005
Marcus's Avatar
Ok, I guess I will try that nexted. But If u connect it to the battery The gauge will be on all the time.
Old Mar 21, 2005
Marcus's Avatar
Alright I tried that when I disconnect the amps power I got above 14 volts.. When I have it on I get 14 right on. Thanks A lot for helpin out
Old Mar 21, 2005
Marcus's Avatar
Oh and When I idle I get 14 volts
Old Mar 21, 2005
Octane Joe's Avatar
I would say that if you are not running anything off your cig lighter, try hooking it up to that, It turns off w/ the car and at least w/ my experiance, has given a fairly accurate reading... I have a sub and amp, it drops when I run the system hard, but never below 12... but then again, I also have a spike cap... hope this helps...
Old Mar 21, 2005
Marcus's Avatar
thanks, it is. ANything would
Old Mar 21, 2005
Octane Joe's Avatar
we need more people w/ your addituted! rep+
Old Mar 21, 2005
Rep for those that helped?
Old Mar 21, 2005
J187's Avatar
HAHA, asked a question get rep. What a world, J/K
Old Mar 21, 2005
Octane Joe's Avatar
hey, what the hell, Im in a good mood! there ya go! rep+
LOL, well ya know, I did give you some advice... you ...could... return the favor, lol
O, and while we are all being cool, if you could check my last post and let me know what you think, that would be great! clicky, clicky
dtdoyle
25
Aug 30, 2015 06:57 PM
JetsterDajet
Aug 16, 2015 01:56 PM
martinsmartin
Aug 15, 2015 07:34 PM
jnissen
Aug 9, 2015 05:34 PM
jzhartman
22
Jul 23, 2015 10:42 PM
