Keep blowing my 4 GA Fuse?
Old Mar 18, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
Here is my setup.
Battery->4GA Wire->1F Cap->Power Dis Block->2 8Ga Wires->2 Kenwood KAC-7202->2 AudioBahn 400RMS (each)
BTW, the 2 8GA wires also have fuses, but they are not blowing.
I just got these new amps yesterday, installed em, and after I turn up the sound I will blow the fuse on the 4GA
Gain = 50%
Sub Power on Receiver = 30%
Volume I turn it up to = 40%
Then the fuse pops, it was a 60A, replaced it again, popped, replaced with a 100A, popped, I have one more 100A fuse left. What am I doing wrong?
I do not have the Big 3 done yet *I recently ripped it out when dropping the engine with plans to redo it*. I do plan on doing that again, but anyone know what the problem could be?
I do get a good amount of bass as I turn up the volume, but I know these subs/amps are capable of more, I THINK its because the amps are trying to pull to much power?
Old Mar 18, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Well for starters, one thing you are doing wrong is one of the most foolish things you can do - replace a fuse with a higher rated fuse just because it keeps blowing. Eventially, you'll find a fuse that won't blow even though there is a power surge/spike and because the protection(fuse) doesn't work when its too high rated, you'll start a nice little warm cozy fire in your Civic. That being said, you've got to find out why the fuse is blowing. Check your power leads and you grounds and make sure they are good.
Old Mar 18, 2005
chaoticmav's Avatar
I had talked to someone and they told me I could either go with 80A or 100A but no higher, and I found some so i bought 2, if I get the problem solved i will probably go back to 60 or 80 anyway.
Old Mar 18, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
check your power wire... is there any contact of it underneath the engine bay or nearby firewall?
i was in the same situation and i figured out my power wire was aside my tranny case which gets really heated and melted thru the wire.
Old Mar 19, 2005
chaoticmav's Avatar
My wire is all good to go, nothing wrong it, ripped it out and checked. Well I checked my fuses, my 100A fuse didn't blow this time, but my amps one did. My ones on my 8GA didn't argh. So after I replaced the 40A on the amps tomm from work (Best Buy) and get a 80A for my Power line, gonna try it agian. I still CAN NOT figure out what is going wrong, any help would be appreciated.
Old Mar 19, 2005
alex053's Avatar
what are the fuse ratings on your amps....add them up and thats your main fuse value. then do the same for each 8ga going to each amp
heres and example
sub amp - 2 30amp fuses (60)
4 channel - 2 20 amps fuses (40)
so the main power wire needs a 100A fuse, the 8ga for the sub amp needs a 60, the 4 channel 8ga needs a 40 amp.
Old Mar 19, 2005
chaoticmav's Avatar
Yeah I did, i need 80 for my 4ga, and 40 for both 8ga, there are inline fuses on the 8GA, and bus on the 4ga, so I will by everything right for tomm, I just need to find out why it blew 2 of my 60a, and then blew my amp fuses, I check my grounds, they are all good. I grounded my batt with 4Ga today, *just preparing when I get my system back together*
Old Mar 19, 2005
DBDIJON's Avatar
DBDIJON is an unknown quantity at this point
If the fuse in your amp popped you have a short in the amp or the subs are wired to to low of an impedance. Try hooking power back up and leaving the subs unhooked. Also how big is the fuse on the side of the amp? Is it 80 or what?
Old Mar 20, 2005
chaoticmav's Avatar
40A on both amps
Old Mar 20, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
do not do that, itll only hurt ur system or even worst, fry it.
sounds to me that you have grounding problem. find another grounding points, like the seat belt bolt and make sure it not on paint.
Old Mar 21, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
If you already checked your grounds and your power wire, I would start eliminating things such as your cap and your distribution block and see if the fuse still blows. Also what dbdijon said is a good idea as well to unhook the subs and see if you're stilll blowing fuses. But don't replace fuses with a higher rating.. you can easily start a fire and cause injury to yourself and/or others.. if you're in doubt, ask before you do something like that.
Old Mar 21, 2005
chaoticmav's Avatar
OK, I replaced the ground wire running from the CAP to the frame, found a new grounding spot, made sure i sanded off the paint, regrounded the amps in the same spot. Now I am blowing the amp fuse, ALS:KJD:AKJ it is a 40A I blew, and its a pain in the *** to get those * i can get them from my install shop my they will only give me so many lol*
Old Mar 21, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Have you tried it without your subs hooked up? I'm guessing you have them wired to 1 ohm or something like that and your amp can't handle the load.
Old Mar 21, 2005
chaoticmav's Avatar
I have them wired in series, to 8 ohm *each*
Old Mar 21, 2005
eye_see_you's Avatar
let the devil out
figure out how many amps total is needed per amp and that is the fuse you should have on your power lead form thr battery to the dirtobution block or cap. then from there you have fuses on the amps etc. So far it sounds like 100amp is what your needing but you have something worng such as a bad ground or unknow grounding point that keeps blowing your fuses.
Old Mar 21, 2005
chaoticmav's Avatar
There is a 40a on each amp, so I should need a 80A fuse, but I couldn't find one *at the time* so I am using a 60A. But I still managed to blow my amp fuse, and what gets me is, the 8Ga I have running from the block to the amp has a 40A inline on it, that didn't blow, grr. All the connection on the amp are ok, and it only happened after i turned it up so loud *about 50% of its power*
Old Mar 21, 2005
let the devil out
possibility that your drawing to much current you have not listed your amps . so list the amps , their fuses and I think we have an idea of your wiring setup.
Old Mar 21, 2005
chaoticmav's Avatar
Kenwood does not have it on their site yet or i would link it.
KAC-7202
920 WATTS MAXIMUM POWER OUTPUT
460 Watts RMS at 4 Ohm x 1
2 Channel Power Output
MOSFET Power Supply
Torroidal Noise Suppression Filter
Copper EE Core Power Transformer
Dual Secondary Capacitors
Ground Isolation Input Circuit
Detachable Aluminum Dress Plate & Top Panel Control
Die-Cast Aluminum Heat Sink
Cast Aluminum Sandblast Finish Heat Sink
Variable (50-200 Hz) 18 dB / Octave Low-Pass Crossover
Switchable (150 Hz) 12 dB / Octave High-Pass Crossover
Switchable 12 dB Bass Boost at 90 Hz
Preamp Outputs
High and Low Level Inputs
2 Ohms Stereo / 4 Ohms Mono Stable
Red Triangle Power Indicator
Screw-Type Power and Speaker Terminals
Single-Side Terminal Placement for Cleaner Installation and Improved Wire Management
My Subs:
AW1251SE
12” NATURAL SOUND WOOFER
45 oz. Strontium Magnet
Power Handling: 400 watts R.M.S.
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
Mult-Connect Lug Lock Terminals
My Setup:
2 AW1251SE in a bandpass box.
Each connected to its own KAC-7202
I have 4ga running from battery to a capacitor, then from the cap to a power dis block.
From the block 2 8Ga run to each amp with its own inline 40A fuse, the amps also have a 40A fuse *just 1*.
I have each sub bridged on its own amp.
Old Mar 21, 2005
chaoticmav's Avatar
I think I am going to get rid of the distribution block. Rather then running my 4GA to my dis block, send it to the amp, and add another 4ga wire to the cap and run it to the 2nd amp.
Old Mar 21, 2005
let the devil out
ok so according at most you should have an 80amp fuse with the posibility of a 100amp fuse. now as far as blowing the fuse each time I think you may need to check yoru power wire fmor the battery all the way back because it sounds like its grounding out or maybe even that your new amps may be defective. I see this happen once before where the fuse kept blowing with a kenwood amp no matter what fuse we threw at it. Turned out after many calls to tech support that it was a amp board problem.
Old Mar 21, 2005
chaoticmav's Avatar
I did check the power wire, I thought of the possiblity of grounding out, but its only when i turn it so high, if I had a bad ground it would blow automatically wouldn't it?
Old Mar 21, 2005
let the devil out
so this narrows it down to possibly pulling to much current at once when they are turned up the gain not being adjusted correctly or possible defective amps.
Old Mar 21, 2005
profuse007's Avatar
Senior Member
someone mentioned unhook ur subs. what theyre talkin about is that its possible that youre under-driving ur subs and cause it to blow.
Old Mar 21, 2005
I think you should first unhook your subs, play it loud and see if you blow the fuses like some of us have been telling you to do.
JetsterDajet
Aug 16, 2015 01:56 PM
adamdrives
15
Aug 8, 2015 08:53 PM
exiled1
Aug 8, 2015 06:09 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
