custom box
Old Mar 15, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
custom box
anyone build a custom enclosure for 1 10" or 12" sub, im thinking about making something for mine but not sure what to do, any pics would be awesome.
Old Mar 15, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I know it sounds lame, but cruthfield has a pretty decent DIY
Old Mar 15, 2005
CplJon's Avatar
Rape is no laughing matter--Unless your raping a clown!
CplJon will become famous soon enough
You could use this as a basis for where you start, but keep in mind it is designed specifically for a Diamond Audio sub.
File Type: doc
Old Mar 15, 2005
J187's Avatar
The one thing that I'll tell you from experience that not a lot of DIYs mention I think. When you assemble the box. The longest sides go on the outside to increase rigidity.
Old Mar 15, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I wouldn't start with the transmission line box CPL john posted for a first box I've ever built. Those are very precise designs, and require lots and lots of scheming, planing, and preciseness.
Were this the first box I have ever built, I'd build a sealed enclosure, as you pretty much can't mess them up (unless you don't give the woofer enough airspace.). Don't forget tofigure in displacement.
If you're planning on building more than one, you might want to invest in the loudspeaker design cookbook, as it's a valuable read for newbs and old timers in the audio world alike. Lots of info is out there to be learned.
Some sights I'd recommend looking through(other than here) are www.termpro.com
www.the12volt.com There are resources out there, but you need to be more specific as to what you're looking for out of a "custom" box.
Old Mar 16, 2005
J187's Avatar
Two more bits of advice for you.
1. Think long and hard about which ends are going to overlap to account for the wood thickness. For instance, a box that is 12" tall might have a 12" front and back, but the sides might have to be 10.5" inches tall if they go between the top and bottom and you are using 3/4" wood. . .
2. Cut the hole for the woofer(s) in one of your sides BEFORE assembling the box. That way, if you F it up you only have to re-cut one piece Especially if you are using a jig saw and especially if you are particularly uncoordinated.
Old Mar 16, 2005
ncirom2003's Avatar
somebody had posted a DIY on building a custom fiberglass box and had good pics and details also. check out the jl audio (i think) sub box that hides in the corner of the trunk behind tailight
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
