question about terminals in the fuse box.
Old Mar 7, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
In the fuse box in the engine compartment there looks to be two terminals you can use to tie in accessories. Is this what they are for?
If they are; does anyone know if its safe to run 1/0 for my amps to this?
I'm thinking that if these terminals are to be use for acessories it may also be tied into that circuit that judges current demand and will run the alternator more to supply the extra current.
Old Mar 7, 2005
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
1/0 needs to go direct to battery, acc circuits are OK for lower amperage applications.
Old Mar 7, 2005
MassMayhem's Avatar
as a side note, something tells me you have no idea what you are talking about.
Old Mar 7, 2005
jttegx's Avatar
OMNES AD UNUM
do you have a photo of what your referring to tbaleno?
Old Mar 7, 2005
tbaleno's Avatar
Lets start from step 1.
If you think I'm an idiot I refer you to this thread with pictures.
http://www.7thgencivic.com/forums/sh...light=charging
In the picture in that thread you see some cables coming off the fuse box.
I was wondering if I could run 1/0 to those posts and if I did would it show a load to the ELD.
Secondly I was wondering if the ELD (If you don't know what it is then you obviously didn't read that post I refred to) would blow up if I hooked up my power to those posts.
Old Mar 8, 2005
04civicvp's Avatar
04civicvp is an unknown quantity at this point
Those posts are actually connected directly to the battery, before the ELD. You can hook up to those, but they are not going to show the extra load to the ELD. If you look to the left of those posts, you will see another connection that is available. I am thinking that hooking up to that one will show the load, but not sure on this yet.
Also, as stated above I would not hook up 1/0 or any gauge wire that is larger than the wire currently connected to those posts.
Old Mar 8, 2005
paradoxblue's Avatar
yeah tose are the connection points to the battery for the fuses i believe. so i dont think it would be any different then a direct battery hook up
Old Mar 9, 2005
tbaleno's Avatar
Thanks. Thats exactly the information I was asking for.
Old Mar 9, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
I connected two 8 ga wires to those posts in both my vic's. No problems for 2 years now. I don't think you can go with any wire bigger than that though. It be pointless because the source wire from the battery to the terminal is 8ga.
roverben
Jan 21, 2019 05:16 PM
jbdewitt
Jun 16, 2015 01:36 PM
duder
15
Jun 11, 2015 04:28 PM
Black91civic
Jun 6, 2015 08:15 AM
viper775
Dec 9, 2001 10:52 PM
