Alpine Aux. input wire?
Old Mar 4, 2005
wizawaza's Avatar
wizawaza is an unknown quantity at this point
Where would i get a wire to plug into my aux input on my alpine cda-9830 from a sony 7 inch fold out tv to run the sound through my speakers of my nissan pathfinder?
Old Mar 4, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
check the alpine manual, Im pretty sure its a KCA 121B cable.
Old Mar 4, 2005
wizawaza's Avatar
that will hook up the sony tv to the aux. port of the alpine cda9830
Old Mar 4, 2005
CivicHX01's Avatar
3187 is right... you need KCA-121B to convert the AI-net input on the alpine to an aux input... then you run RCA cables from the sony audio output to the input on the alpine...
you can also use an FM modulator on the 7 inch and then tune the alpine to the set frequency, that way you can use the AI-net input for other stuff like an IPod or MP3 player...
Old Mar 4, 2005
Al Gore FTW's Avatar
jdmtytedoridori
on ebay you can get a kca-121b for like 10-25 dollars. hooking up your source directly is sooo much better than fm modulator. i have my delphi xm roady2 hooked up through it because i couldnt stand the fm mod.
what you could do if you want to hook something else up later on is just put an rca y-cable thing on the red and white plugs of the kca-121b, then just hang that behind your dash to plug other stuff in later.
Old Mar 5, 2005
J187's Avatar
you can also get a complete dual AI Net converter cable. Like the 121b only it allows multiple devices, I think. Check the manual.
Old Mar 5, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
All of the Ai-Net accessories (satelite tuner boxes, changers, and the ipod adapter, etc.) have a 2nd input on them, so even if he wanted to use one of those with the 121b he could no problem. (I am using the 121B and an original Alpine XM Tuner)
Old Mar 6, 2005
jdmtytedoridori
the ipod adapter does not have a pass through, i saw it on display the other day at a local car audio shop. the sat tuners anre changers do though.
Old Mar 8, 2005
CivicHX01's Avatar
yea, i think that adapter is kca-410c... it converts the 1 AI net into 2 AI net's and an RCA input...
mistermenphis22
Jul 13, 2015 04:43 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
BootyDo
Jul 7, 2015 06:06 AM
robbie374
Jul 7, 2015 02:56 AM
