how many people have JL 12w7 in there civic?**PICS**
Old Mar 3, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
HI i just bought 12w7 and JL 1000/1 amp. I am just wondering how many people have 12w7 in the civic? if you have 12w7 sub in your civic please post some pics. I want some idea on what kind of box i am looking for. And i have an issue where i blew two kicker amps. And i am wondering if bad ground would do it? and can bad RCA connection blow amp?
UPDATE
I can't believe my ear. This thing is loud. I won't doubt if this think break the plastic piece that covers the back speaker.Man i wish you guys can hear this.
Old Mar 3, 2005
locolouie's Avatar
locolouie is an unknown quantity at this point
I had the JL's
I blew them like 2 times, now i have the memphis m3's. they are awesome, and they pound!
Old Mar 3, 2005
Where did you ground your amp. I had my amp grounded to the tail light. I need to find better spot to ground?
Old Mar 3, 2005
Jeromie's Avatar
Jeromie is an unknown quantity at this point
heres my w7
http://members.cardomain.com/rican408
Old Mar 3, 2005
^^^ hi what amp are you pushing the sub with. And how loud is it compare to those 3 12's you had before. I know the SQ is lot better. And last,but least where did you ground the amp?
Old Mar 3, 2005
diskreet's Avatar
You know the metal hump on the "floor" between the seats and the trunk...i grounded my JL 500/1 there...with my own special grounding screw (aka some screw laying around the garage that day) and it works perfecty. try getting the paint off where you ground to get the best connection possible.
Old Mar 3, 2005
jttegx's Avatar
OMNES AD UNUM
when i hooked my system up, i hooked up the ground behind this area of carpet in the trunk on the right hand side. ( i think the left hand side would do too). if you lift the grey carpet layer, you cant miss seeing the frames of metal/steel. your gonna need to sand off the leftover paint so its bare metal.
sry to whomever original photo that is
Old Mar 3, 2005
diskreet's Avatar
also congrats on the 1000/1 and W7 but man your lights are going to dim so bad!
I got 1/2 that much power and its a real problem. Have a headace from the bass for like 4 hours now. ever since dynamat my subs have been killing my head.
Old Mar 3, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
yeah use a dremel to sand off some paint, then use a sheet metal screw.. a seatbelt bolt works good, otherwise any place where there's double metal is good for a ground. Yes a bad ground can fry an amp.
Old Mar 3, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
I did the same thing. All you gotta do is drill sand some paint off on a small surface, and then drill a hole. Once you drill the hole just screw down the ground wire. I used a washer, cause the connector on the ground wire was bigger than the head on the screw.
Old Mar 3, 2005
phuviano's Avatar
How much sq ft of dynamat is that?? Does your trunk still rattle at all?? I was thinking of using dynamat for my trunk, but that stuff is pretty expensive.
I could care less for improved SQ, I just don't want my trunk to rattle. Its not bad now. In some of the songs only when the really low bass hits, my trunk rattles.
Old Mar 3, 2005
^^ This is WAY off topic but your avatar is GREAT.. I'm like.. obsessed with christina (not in a dangerous way).. anyways yeah, If at all possible, use a star washer because after you tighten it down to a certain point, the teeth in the washer help create a more secure ground.
Old Mar 4, 2005
diskreet's Avatar
I used two and a half sheets of dynamat xtreme just on the trunk lid...10 square feet.
and yes my trunk still rattles! Subs hit alot harder and rear deck lid shakes so so much more. I have about 12 square feet left over now from the install (Xtreme trunk kit and wedge pack) so Ill be doing the deck in spring if I ever feel like taking it apart.
Old Mar 4, 2005
eye_see_you's Avatar
let the devil out
well currently I have 2 12" wls Power acoustics in a fiberglass box being pushed by phoenix gold amps but I have decided to put in a single 10w7 fed by a 500/1 and a 300/4 to push my doors and rears. I have my ground bolted in the tirewell and using a 5farad alumapro cap with a yellow top optima battery. Head unit is a clarion vrx935vd w/changer and so far no major issues.
Old Mar 5, 2005
Come on guys there has to be more JL setups in civic. Bring it on.
Old Mar 5, 2005
diskreet's Avatar
Last night I secured my amp MUCH better and revearsed the L brackets I had holding the bow in so that now it sits on the bottom and you only see on side.
That board used to just sit in there and now I put 7 zip-ties and 4 screws through it to keep it there. And now it doesnt move at all!
Old Mar 5, 2005
^^^^ that's sweet.
Old Mar 5, 2005
I am going to install my 12w7 and JL 1000/1 tomorrow hopefully. Trying to get of work just for that.lol. About the rattle. hate that plastic piece that covers the back speakers and third brake light. Its rattle like a mother with just my comp vr's. HOw do i get rid of that?
Old Mar 5, 2005
Excal's Avatar
blah™
Excal is an unknown quantity at this point
ive seen people say they have put foam under it...one guy put a yoga mat under it. Anything really would work as long as the plastic isnt hitting the metal thats where u get the rattle from.
Old Mar 5, 2005
hustlelikem0fo's Avatar
just wondering, how much does that set up cost? the 12W7 and the 1000/1 JL amp.
Old Mar 5, 2005
well I am getting mine for mad cheap. $1400 plus $250 for the box. everything with 2year warrenty. If the sub or the amp blows i just take it back and get a new one.
Old Mar 5, 2005
Neptune's Avatar
Neptune is an unknown quantity at this point
thats still dammn expensive
i think ill be holding off!
Old Mar 5, 2005
You get what u pay for.
Old Mar 5, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I got two 10W6V2 and a 500/1 and I'm madly in love with them. I'm doing a JL theme in my trunk, I'll post pics when I'm done
Old Mar 5, 2005
J187 where did you ground your amp?
Old Mar 9, 2005
my pics added
Old Mar 9, 2005
so the sub and the amp were 1400 total?
Old Mar 9, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Ground it where ever you feel like grinding the paint off.
As for the rear deck rattle, sound dampener, and lots of it. I might even recommend carpeting it, as it'll still rattle against the glass. For a temporary fix you can cram old socks or anything in there to keep it from contacting the glass.
Old Mar 9, 2005
zachgeyer's Avatar
spray foam help too
Old Mar 9, 2005
aZnVoYCe's Avatar
Not mine but a friend's car.
