BATTERY RELOCATION--check out the pictures... =D
Old Mar 4, 2005
  #31
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
youre gonna need to upgrade the wires to at least 4 for sure. as far as fumes, you need to seal the top portion and ventilate from the bottom. better yet, you might to invest in some gel battery.
Old Mar 4, 2005
  #32
eye_see_you's Avatar
let the devil out
you should have atleast 4gauge wire from the trunk to the engine bay for a battery relocation . I have the yellow top optima replacement for our 7th gen and its 450 or so cranking amps, cost me about 118.00$ but I've had no issues at all since I put it in.
Old Mar 4, 2005
  #33
orion_squall's Avatar
hi,
Did you ground the battery to the chassis ground?
Also, once mentioned that you should use a larger diameter wire. He is right, larger diameter wire means lower resistance, therefore you won't have current loss.
Old Mar 4, 2005
  #34
pnoyster2k1cvic's Avatar
Balut Eating Champ
i just ordered a 2gauge wire to be delivered in about couple of days... definitely the pipe ain't big enough to deliver the water to the faucet that was an "idiot proof" explanation and yes... i will also get the Optima batteries... D31T sounds good? but as far as ground, 8gauge wires would be fine or I also have to have atleast upgrade it to a 4gauge wires?
Old Mar 4, 2005
  #35
WhiteRabbit's Avatar
youll have spare 2 gauge. use that. 8's definitely not enough
Old Mar 4, 2005
  #36
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U get a voltage drop over long distances kinda like an extension cord and a hot glue gun. The gun will take forever to get hot. Try using a smaller GA to compensate for the distance.
Old Mar 6, 2005
  #37
Balut Eating Champ
i'll let you guys know when i get the 2gauge wire in... and also i already ordered a D31A optima battery, this thing should be great with my system!
did anybody changed their alternator to a bigger and better one? how much? where to get? thanks!
Old Mar 6, 2005
  #38
HondaGuy12's Avatar
Fiji Club Member
u should just go with the optima....you get a lifetime warranty on it or intill you sell your car...
Old Mar 6, 2005
  #39
Neptune's Avatar
Neptune is an unknown quantity at this point
Originally Posted by diskreet
i know what some of the problem is..
that tach!
take off the glittery rubber steering wheel cover!!
Old Mar 6, 2005
  #40
paradoxblue's Avatar
Originally Posted by Neptune
take of the glittery rubber steering wheel cover!!
ahaha yes omg :|
Old Mar 6, 2005
  #41
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I have done this in my old astro van successfully for the reason of when I had my 12 - 12"s and 6 punch amps for spl, I had several attemps of thievory. They were trying to drill a hole right in the battery I kid you not, Why would they do this ask you? Becuase once the acid has drained out the battery no longer can power the alarm. This was ofcourse before I purchased a back up battery. But I used nothing less than 1/0 guage. You can get it for a dollar a foot at any welding supply store, If you dont care what it looks like. Also ground obviously most be less than 18" I ran mine directly to the frame @ 14". Reason why is that my motor's main grounding resides on the frame, which was the shortest distance from battery to starter.
Old Mar 6, 2005
  #42
Balut Eating Champ
Originally Posted by paradoxblue
ahaha yes omg :|
hahaha! leave it alone! that steering wheel cover helps me when I make turns... i have the habit of using one hand, while driving but it will stay there untill i can afford to get me a momo SW...
Old Mar 6, 2005
  #43
:| hahaha
Old Mar 6, 2005
  #44
profuse007's Avatar
Senior Member
thats always been the issues w/ car products, lifetime warranty is not transferable. its rather smart move for the product maker, they prolly did a research on it... ppl will tend to keep the car w/in ~5yrs or so.
Old Mar 6, 2005
  #45
Balut Eating Champ
you're so right about that! i almost sold my car for about 3 times now... but the offer wasn't right so that's why i still have it... fukin s2k still hunts me in my sleep, this probably won't stop untill i get the bitch... i guess...
Old Mar 6, 2005
  #46
Bires's Avatar
Bires is an unknown quantity at this point
Originally Posted by pnoyster2k1cvic
^^^that's fine i know he's ignorant as ***! just the PTSD got into me...
BWAH HA HA HA
Well put.
By the way:
1. People like you are the reason ricer children get the street rep they have. "I will kill you with my 1.7L 4 cyl engine!"
2. I have a master's degree in physics education
3. "****" is spelled with a "c"
Old Mar 6, 2005
  #47
hahahahaha
Old Mar 6, 2005
  #48
hojo35's Avatar
hojo35 is an unknown quantity at this point
Hereshttp://img54.exs.cx/img54/8466/trunkbatterybox4wk.jpg my battery relocation box.
Old Mar 6, 2005
  #49
4Saris's Avatar
4Saris is an unknown quantity at this point
It looks like it's ....."For her pleasure".
Old Mar 7, 2005
  #50
Balut Eating Champ
focus people! aight all my extra gadgets came in today... i.e. battery POS terminal with volt meter, nice sparklin NEG terminal with 0 2 4 gauge connectors... i'm just waiting for my D31A battery
Old Mar 7, 2005
  #51
Balut Eating Champ
Originally Posted by Bires
BWAH HA HA HA
Well put.
By the way:
ow wow! master's in physics? and you're teaching me how to spell ****??? you ****er i know how to spell ****, but you won't be able to see the **** word so **** you!!!
1--you should join the marines or spec ops, they will need that physics education you earned? if you have the ***** you chicken ****!!!...
2--my car's faster than yours
3--the tach stays
Old Mar 7, 2005
  #52
the monster 5" tach is needed to match the exhaust pipe.....
Old Mar 7, 2005
  #53
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Tach? I thought it was a wall clock
Just kiddin' man.
Old Mar 7, 2005
  #54
Bires's Avatar
3--the tach stays
1--I teach in the public high schools. Don't call me chicken. For that matter, don't call me ****. Hey don't call me at all. I have plenty of friends with normal blood pressure and neurochemistry.
2--Most likely you're right. My civic is sound deadened, and has an upgraded sound system. I put close to 200lbs in it above stock just for sound quality and driving pleasure. I love driving my car. All the time. Not just for the 7 seconds or so until I get to freeway speeds.
3--Cool. Keep the tach. Add a few more. Eventually, your dash will look like a the con of a WWII submarine. Take lots of pics. Besides, someone has to keep the Taiwanese children employed by buying their ricer trash.
Old Mar 8, 2005
  #55
Balut Eating Champ
whhhhaaatttt!!! my exhaust is not that big guy! second it had to be atleast 2.5 just to get some air flow goin... if you're not boosted, you will never understand... and last... like I said before that tach is there for a purpose, i AutoX and Drag Race... now ya'll just hatin on my ride, coz i can smoke your 7thgen like you're on reverse... and I still gain whp after 5500+ RPM!
Old Mar 8, 2005
  #56
Balut Eating Champ
so since when did Autometer produced their equipment from Taiwan? the last time I checkedc, it was made in the U.S.
www.autometer.com
Auto Meter is an American owned and operated company and we greatly appreciate that you have made us America's No. 1 racing instrument manufacturer. Since our beginning in 1957, we have devoted a tremendous amount of time and resources into maintaining a strong leadership role. We are serious about manufacturing the absolute best instruments in the automotive aftermarket. Our commitment to NASCAR Winston Cup, Busch Grand National, NASCAR Craftsman Series, NHRA and IHRA helps to insure that drivers can rely on the products we produce. Our involvement allows us to provide innovative, useful instruments for all classes of racing. After all, Stock Car Racing, Drag Racing and Street Rodding were "Born in America" and we are glad to be your partner in this exciting business.
so all race cars are now called "RICE" because they have tachs on them???
Old Mar 9, 2005
  #57
ShadyImprtracer's Avatar
ShadyImprtracer is an unknown quantity at this point
reading this thread gave me another reason to not be boosted. i bought the HP performance kit that requires the battery to be moved to the trunk. well the person i bought the turbo kit from forgot to send the battery relocation kit since it comes with it. its cokblocking me from my install cuz im still waiting for it to get to my house...keep me posted on the battery relocation though and try to take more pics of it cuz im doing the install on my own
Old Mar 9, 2005
  #58
ren808's Avatar
ren808 is on a distinguished road
Originally Posted by SkipBarber
when you took the battery out of the car, did you rest it on the floor? on concrete? I learned that by putting the battery on a concrete floor, it starts to discharge rapidly.
thats a myth........ i had a bat. sitting on the floor for over six months and nothing happened. regardless if its sitting on the floor it will still drain, i used to work in a auto parts store so even bats. on the shelf would drain...........
Old Mar 9, 2005
  #59
J187's Avatar
Dude, the problem is, you're talking about racing mods in a room full of audio nuts. We usually dont' understand eachother. I'm not against modifying a car for performance, I just personally wouldn't waste my time modding a Civc. I have a 320hp blown Grand Prix so I guess you could say I AM boosted and I still don't understand a huge tach in a civic. It' s just my personal preference. I'm just trying to tell you that you aren't gonna get a lot of sympathy in here for your "rice"-like modifications. So, it's probabl;y a waste of time to sit in here and defened yourself and go on offense attacks claiming you could beat anyone here in a race hands down. We aren't into racing our Civics. If I wanted to keep up with you in your Civic, I'd simply hop on my Honda CBR and in a little over 3 seconds, I'll be going 60mph . . .
Old Mar 9, 2005
  #60
Balut Eating Champ
dood! this thread was first all about the battery relocation... so it's now my fault that ya'll whored out my thread???
Reason for the tach
--you maybe driving an auto and you don't need to shift gear...
--I want a precise shifting, right after 6RPM
--do you auto x? have you driven a course that you can only be on 2nd gear tops??
--have you had your 7thgen boosted and set the VTEC at 4500 or 5K RPM? you have no idea how fast the RPM goes after the VTEC kicks in
--i don't need your sympathy and lets focus on the batter relocation...
