Made my own Power Hub, Wutcha Think?
Old Mar 3, 2005
paradoxblue's Avatar
I am running a number or 8 awg lines through my firewall. inside the dash i needed to make some kind of hook up for easy access to adding lights and other rice
so i came upw ith this
I purchased a 8 screw thingy.. NO idea wut its called/for.. maybe u guys know? maybe this IS wut its for? lol
so i decided i only really wanna run 4 points of a 8awg line so i used two lines.
i also am going to cover the red wire with a blue sheething stuff in the engine bay just cause its the hot shi.t
anywho. here's the pics.. wutcha think? i tinned the wires with solder to make them a bit harded. but because the wires so thick it looks a little crappy heh. but oh well it does the job
Name:	8awg 8point bridge 001.jpg
ID:	48774   Click image for larger version
Name:	8awg 8point bridge 002.jpg
Old Mar 3, 2005
diskreet's Avatar
Dont run an amp off that...only lights and low current stuff. The power strip will not be able to handle too much power. And thats nice but you need to cover the whole thing. If you can after you wire everything up wrap it in electrical tape to prevent it from falling apart or grounding itself on anything. NO BARE METAL!
otherwise good idea...just be careful with it.
Old Mar 3, 2005
yeah it will be instulated with red electrical tape when installed.
and no these are for lights and other crap. im running 3 more 8awg lines direct to my trunk.
one for an xbox
and 2 for amp's for when they get installed
Old Mar 3, 2005
eye_see_you's Avatar
let the devil out
you could of just got a distrobution block and had things look nicer and be more safe. As for the current setup it can work but its not a recommended solution because they make distro blocks for just that purchase that can accept one incoming connection with multiple outputs.
Old Mar 3, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
I've got distruibution blocks for power and ground, maybe 35 for both, total and they're gold plated, etc......you get what u pay for
Old Mar 3, 2005
yeah but i have yet to see blocks provind 8 gauge in and like 12-18 out.. this is to be hidden under the centre console for running speaker type wire.. thin crap
i will be using distro blocks for everything else. including what these plug into. no worry's
Old Mar 3, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
That is exactly what that is used for - power distribution
Old Mar 3, 2005
the only distro blocks i have or have found are for larger guage wire like 10awg+
nothing for the smaller crap thats comes with lights
not to mention distro blocks arn't cheap. and when i will hooking up 10 or more light set's i dont want to have to pay 35 bucks for a block for every 4 lights
this ws cheap. and it works.. won't have any seriosue ampage on the line so it should be fine
Old Mar 3, 2005
h0nd4_r1c3r_X's Avatar
h0nd4_r1c3r_X has a little shameless behaviour in the past
Thumbs down
im i the only one that thinks this is a fire/accident/crash waiting to happen?
Old Mar 3, 2005
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
Nice Carpet Pube dude, upper right hand corner for those of you who can't see it.
lol
Old Mar 3, 2005
lol its sitting on the carpet in my living room. and i dont think thats a pube hair. probably dog or human head hair :| but wut ever gets you off..
it wont be mounted on carpet and its going to be completely enclosed
Old Mar 3, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
thats a barrier strip. Usually its used for low current hookups. Tim Baile used it so he could disconnect his amp in an installer easier, it was a creative way to install it.
Old Mar 3, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
how so?
Old Mar 3, 2005
the more unexposed wiring, the higher a risk of shorting out the wire. If the strip isn't secured well, one of the soldered wires could snap
Old Mar 3, 2005
diskreet's Avatar
he said it will be covered people. as for the xbox I have a power inverter running off the cig plug + and -(i know but it works) and the inverter behind my HU. Xbox is under the passanger seat and fits perfectly NO mounting hardware required. perfect fit.
Old Mar 3, 2005
anything installed in a car should be mounted, having equipment laying on the floor, even though it fits, it isnt safe. Cars are a harsh environment. Lots of bumps, jolts, and acceleration/decceleration forces
Old Mar 3, 2005
haha the xbox is coming in another story :| lol im owkring on a wiring diagrama nd **** right now
as for that barrier strip it works great. and will be screwed to a metal frame piece in my car.. so i should be safe :P
i will be running really low gauge wire from the engine bay into a gromet threw my trunk and putting a block there for 8awg wire for my xbox etc.
it will come into picture.. i have enouhg electrical and home wireing knowledge to not burn my car out
GolNat
Suspension DIY
May 12, 2022 06:49 AM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
rtachs
Jul 16, 2015 05:32 PM
bsmiley
Apr 27, 2015 01:27 PM
SSMatey
Apr 13, 2015 06:09 PM
