Rattle Behind Rear Seat
Old Mar 2, 2005
Slick911's Avatar
Slick911 is an unknown quantity at this point
Hey,
Well my problem is in my 03 Civic 4dr, when i turn up my sound the plastic covering behind the rear seat that holds the 6.5's seems to be loose and rattles. Are there any techniques that i could use to reduce this? it really bothers me
Thanks
Old Mar 2, 2005
manahoonie's Avatar
i work at a sporting goods store. we always get samples of the yoga mats that we sell. usually we throw them away, but i saved one, and cut a strip of it to go underneath the rear deck below the third brake light. that worked for solving my trunk rattle! (id didn't at first, but after a few days, it stopped, without me doing anything else to it. who knows?) where are you from? i'd say you can check with the sporting goods stores for similar stuff around in your area. i've also used some packing foam sheets that we get that protects stuff in boxes. it works!
Old Mar 2, 2005
manahoonie's Avatar
im me if you have more questions
Old Mar 2, 2005
Slick911's Avatar
Well no its not in my trunk its from inside the car, behind the rear headrests where the component speakers sound comes in from. The plastic thing i guess has gotten loose because of the subs pounding on it. Thanks tho
Old Mar 2, 2005
manahoonie's Avatar
yeah, that's what i'm talking about
remove that, and stick some foam sheets under it. the rattle you hear is probably plastic on metal. locate where the rattle is coming from. stick some foam between the plastic and metal. should have no more rattle!
Old Mar 3, 2005
Slick911's Avatar
Ohhh Gotcha. Thanks
GotSiR
Jun 23, 2016 04:06 PM
Yazan93
Jul 14, 2015 08:56 PM
fvckbg
Jul 7, 2015 07:08 PM
