help, fuse keeps blowing
Old Mar 2, 2005
diggaflip's Avatar
diggaflip is an unknown quantity at this point
Question help, fuse keeps blowing
my left headlight fuse (in the fusebox) keeps blowin out? dont know why? I have hid's.... origianlly the fuse is 15amp i think... so i replaced it wit another 15amp fuse.. n it blew like a week later..., so i replaced it with a 20 amp fuse n it blew like 2 weeks later? wtf is going on... the rite side is still on its first 15amp fuse n never blew yet... wassup wit my left..can i just get like a 40amp fuse in there n jess hope it doesnt blow?
thanks
Old Mar 2, 2005
paradoxblue's Avatar
u sure there isnt a loose wire or bare wire being ground.. grounding your + line will pop that biotch
Old Mar 2, 2005
diggaflip's Avatar
ill check to see if i have any loose wires... hmm..
Old Dec 19, 2007
SALEEM's Avatar
SALEEM will become famous soon enough
Re: help, fuse keeps blowing
hi i know this thread is pretty old but i am having similar probs. I put in halogen bulbs recently (100w/90w) and every 2-3 weeks my headlight suddenly wont work. high beama and park lights work though. last time i had it serviced in Honda one of the 15A fuse blew but this time i cant find any blown fuses all seem fine. any help will be greatly appreciated. thanks
Old Dec 20, 2007
electric130's Avatar
thanks
okay, this is just really dangerous. the wires are only rated for 15A, so that's why there's only a 15A fuse in there. by placing a 20A fuse (or bigger) you're allowing too much current to flow through there and you are just BEGGING for your car to catch on fire. this isn't a scare tactic, this is the truth. put a 15A back in there before you burn up your car.
that said, you need a relay harness if you want to run HID's. this has been covered tons of times in many threads. again, running HID's off the stock harness is asking for an electrical fire. HID ballasts can pull in excess of 20A during startup. our stock wires aren't designed for that. that's why you need a relay harness with bigger wires that hooks directly to the battery.
JetsterDajet
Aug 16, 2015 01:56 PM
adamdrives
15
Aug 8, 2015 08:53 PM
exiled1
Aug 8, 2015 06:09 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
