Help! Electrical wire cut by accident
Old Mar 1, 2005
Inigo Montoya's Avatar
Inigo Montoya is an unknown quantity at this point
When installing a 4 gauge power wire through my firewall, the coat hanger I was using cut one of the wires in the following bundle:
http://www.7thgencivic.com/forums/at...id=34305&stc=1
It is a blue wire with silver markings on it. The car seems to operate fine, except for the fact that the air bag light comes on. Does anyone know what this wire does? I just want to know if it is okay for me to drive around for the time being.
Old Mar 1, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
ouch, is it cut in half? or just stripped a little? Is it cut inside of the grommet, because you probably could pull the entire grommet out and if you have smaller hands butt connect the wire back together. Anything that has to do with the Airbags is designated with a Yellow harness so I doubt that any of those wires deal with the airbags.
Old Mar 1, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Yes we need more info
Old Mar 2, 2005
MegaHurtz's Avatar
check your power locks
Old Mar 2, 2005
ouch, is it cut in half? or just stripped a little? Is it cut inside of the grommet...
It is cut in half and it is cut inside the grommit. It is really hard to get to also. If I push the grommit through a little bit into the engine bay, the wire gets pulled away from me. I can't seem to pull the grommit towards me. Also, the automatic doors work, and the car drives fine. The only symtom so far seems to be the air bag light. Maybe it has something to do with a sensor in my seat, because it seems that the bundle of wires goes backwards towards my seat.
Old Mar 2, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
if it goes through the firewall and tripped the airbag sensor, it very well could be the wire that runs from the crash sensor to the ECU. I will look up the color code for you in a few minutes.
Old Mar 2, 2005
J187's Avatar
Alright, considering there is no silver wire code, I'm going to guess and say that the wire is actually blue and white. That would make sense because if so, it's the wire that runs from the SRS unit to the airbag inflator on the driver's side. Basically, get it fixed before you crash. Also, you never know with air bags, it's not out of the realm of possibilites that some strange event, static or something, exposes that open wire and sets off the bag in yo face!
BTW, I'm never 100% sure about these diagrams, especially when you are unsure about the color.
Old Mar 2, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Did you disconnect your seats to install your power wire? If so, I'm guessing maybe there is nothing wrong with the wire you are speaking of, just that you may need to reset your light. I would still recommend getting that wire resoldered or crimped at the least. Try pulling one side inside and adding a longer wire, then attach it to the one coming from the outside. Do all of this with your negative terminal disconnected though.
Old Mar 2, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
youll have to get that fix right away. if its merely hanging by strand, the wire can catch on fire due to exceed currents. try pulling the grommet out and connect it again.
Old Mar 3, 2005
Well I was able to connect the wires with a butt connector, (thanks WildRice ) by pulling on the wires, which gave me another inch to work with. Now I have to go about resetting the airbag light. I have read some posts on how to reset it. Can anyone vouch for any of these methods, where you jump the connection with a paperclip? Or should I just take it to the dealer?
Old Mar 3, 2005
skipbarber's Avatar
it's $3.51 at http://www.handaaccessories.com/civmaint01.html
part #07PAZ-0010100
Fastfebur
Apr 22, 2015 01:37 PM
